Old 11-22-2015, 09:52 AM
vajeepj20's Avatar
vajeepj20 vajeepj20 is offline
Noob!
Looking good, that thing should turn out pretty nice when it's done. Have you decided what color you're going to paint it?
Old 11-26-2015, 09:23 PM
BigBlueYJ's Avatar
BigBlueYJ BigBlueYJ is offline
Yeah I have actually started the painting process. The body was in rattle can primer just to keep the flash rust at bay. I threw the fenders on it and some baby tires just to roll it out to clean the garage out before I started painting. Here's some shots of it in rattle can primer....
Cleaned the garage out and got some plastic sheeting hung up to protect the washer/dryer and the other stuff on the shelves. Then I backed the truck back in and dropped it back down to the concrete. Masked the dash off and the engine bay. Also under the cab to keep the paint off the frame. Scuffed the rattle can primer down with some 400 grit.
After it was scuffed up, I mixed up some sealer and shot it. Then I hit it with some high build primer to level out anything I missed.
Then I blocked that down to get it ready for color.
Desert Storm Tan from Hot Rod Flatz. Turned out pretty good. I love the color.
SO far it's just the cab, I finished it this morning. Now I'll move on to the doors, hood, fenders, tailgate, and the small parts. The process continues........
89 Wrangler, 350LT1 sbc, NV4500, NP231 w/SYE, SOA'd with custom framework, HP44/60 locked w/ 4.10's on 36 super swampers
79 FS J10 with 5.3 swap, S465 and 205. Sitting on a HD44/14 bolt and 37's. This thing should be fun to drive if I ever get it finished.
Old 11-30-2015, 07:49 AM
Old Ironsides's Avatar
Old Ironsides Old Ironsides is offline
Nice Work
Great story and nice paint job! I think you are the closest member to me! I work out of Camarillo and drive down there all the time.
Grant
'76 J-10, 401 (1406/2131/DUI/RV Cam), TH400, Part Time, 3" lift, 33s, 346K Miles
'75 J-10, 360 (1406/2131/MSD), TH400 QT, 6" lift, 33s, 100K Miles
'77 Cherokee Chief, 401/Th400, QT, 4" lift... Totalled
Old 12-01-2015, 10:41 PM
BigBlueYJ's Avatar
Well if you'd like to take a look at it sometime, just let me know. I'm always up for talking Jeep. Thanks.
Old 01-05-2016, 09:10 AM
BigBlueYJ's Avatar
A few more updates as the build continues.....
I pulled the dash seeing as I had the windshield out and that was the proper time to do it. It needed a good sanding a a little coat of paint to freshen it up a bit.
I scuffed it up and shot it with some nice semi-gloss black.
Got it put back in and the gauges installed along with a new plastic glovebox and a few silver details to help it out.
Then it was time for the front end pieces..... Had to make room in the garage.... and I finally got to see the color in the sunlight. Looks pretty good I think.....
From there I took all the front end stuff and started sanding them back down getting ready for sealer/primer/color. So much sanding......
Then ALOT of blocking everything back down.... and ready for color.
Let it dry and started adding them on piece by piece.....
Started lining up panels and setting gaps...... UGH. Thats almost as bad a block sanding..... haha. I'm waiting on parts for the door glass so I started installing the grill and lights to see what it's going to look like. I'm not a fan of shiny things and I don't want any chrome on this truck. SO I blacked out the grill and the lights and the pie plates. Goes pretty good with the color I think.....
And thats where it sits as of now..... Waiting on some parts to finish the doors and then have the windshield put in it, along with the back glass. Then I can move on to the bed and get it painted. Then its more tedious stuff.... shocks and mounts, build the steering, finish the exhaust, blah, blah, blah......
Old 01-10-2016, 05:34 PM
Atla's Avatar
Atla Atla is offline
I dig that color with the black trim. Very nice.
~Atla.
My '83 J-10 Rebuild
Old 01-27-2016, 09:21 AM
BigBlueYJ's Avatar
Thanks. I got the shocks mounted and set up. I had to buy another set of shock towers due to the threads on mine were nonexistent on the ends. Then I've since had the windshield and back glass put in it. STUPID WINDSHIELD TRIM!!! I'm having a very difficult time getting that back on so it'll have to wait. I also have the doors assembled and the weather strip put on. All sealed up so it can go outside and sit while I work on the bed. More pics to follow.
Old 02-13-2016, 10:49 PM
BigBlueYJ's Avatar
Got the windshield and back glass installed. Blacked the aluminum around the back glass too.
I ordered up some Bilsteins to fit my lengths. Pulled them out of the box and voided the warranty by drilling out the eyes to fit my mounts.
Found some shock brackets that were long enough to clear everything and started welding them in place.
Once the shocks were installed, I pulled the truck out and rolled the bed back in to get some finish work done.
Hung the tailgate on the motor hoist and strung up some small parts across the back of the bed to get sealed, primed, and painted as well. Then started sanding the rattle can primer back down.
Ran a coat of sealer on everything, then two coats of high build primer, and after blocking for hours, a coat of paint.
I lifted the bed back up with the motor hoist and backed the truck back under it. Sat it down and lined up all the bolts and tightened it down. It's starting to resemble a truck now....
Still lots to do on it but it's getting closer.....
Old 02-14-2016, 08:44 PM
Good progress Jason! Looking more put together than earlier this week.
Grant
Old 02-14-2016, 11:04 PM
BigBlueYJ's Avatar
Thanks Grant. Putting a bed on a truck makes a huge difference!
Old 02-16-2016, 03:05 PM
You're about ready for those 37s!
Grant
Old 03-09-2018, 01:02 AM
Awesome build. Any updates?
Old 08-05-2018, 11:02 AM
Scott2 Scott2 is offline
Swap question
Great truck and awesome work! Question - why didn't the first 5.3 ls motor fit? I thought they were all essentially the same?
I am thinking hard about a 5.3/4L60e swap into my '79 J10 and need to understand what fits and works and what doesn't - Thanks!
Scott
Did I kill some kittens today or just maim them for life? FSJ Guy General FSJ Discussion 18 05-29-2012 06:08 AM
It's the little things: Light Bulbs KensAMC General FSJ Tech 20 01-09-2010 12:13 PM
Duraspark Module Life Expectancy Dan Stewart General FSJ Discussion 11 11-30-2009 02:24 PM
School me on J10s Reebles General FSJ Tech 28 06-15-2006 11:13 AM
New job,and life. How to tow my GW there? Mr. Goatman General FSJ Tech 17 05-01-2006 09:33 AM
