Guys I just want to tell everyone what I found out after some phone calls to Dakota DIgital and HEsco today.If you are doing some sort of gm based TBI or in my case TPI (especially if it is a junkyard swap) you dont have to bypass the VSS just because you have a Cable driven speedo.
What I found out today is that the GM systems require a vss that puts out 8k pulses per mile. After calling hesco and inquiring about their vss used to convert 4.0s into older jeeps, the 4.0 vss is a gm product and uses the same pulse signal. The 4.0 vss is compatible with the d300 (i know from my 4.0 MPFI swap) and should be natively compatible to the NP2XX TCs alot of us are using (sorry qtrac and d20/18 guys you may have to do some more research).
The Hesco vss with the cable output and the electronic out put is kinda cashy. I couldnt confirm if Dakota digital's GM vss would be a direct match but they only wanted 40 bucks for theirs which is a fraction of the cost of the hesco one. Also the sensor was used in a bunch of dodges so if someone knows the models please post up the years for junkyard diving purposes. The only Jeep that had the hybrid VSS is the 1991 wrangler and as far as I can tell 91 was the one and only year that the wrangler had the hybrid vss.
If you already knew this then sorry for being redundant. If you didn't, I hope you find this helpful
