Old 06-14-2017, 02:32 AM
Calebwoodard Calebwoodard is offline
Lift Kit Removal
Im looking to remove the lift kit on my 88 grand wagoneer (was on there when I bought it). I dont know anything about lift kits, I dont even know what kind it is on it. I think im going to need new leaf springs in the back though. Ive got some pics so if anyone knows what kind of lift it has or how to remove it I would appreciate the advice.
https://imageshack.us/i/pm9OZVbcj
https://imageshack.us/i/posd6vL3j
https://imageshack.us/i/pndetc5Jj
https://imageshack.us/i/poimaaUEj
Old 06-14-2017, 10:56 AM
Hmmm, looks like all the other lift kits I've seen. Normally, there will be Part numbers painted on the spring.
Old 06-14-2017, 12:17 PM
The springs are the lift kit. You have springs and longer shackles in the front, and springs and blocks in the rear. To remove them, you'll need to buy new factory-style springs and install them. Just removing the shackles and blocks won't make much difference.
Old 06-14-2017, 08:28 PM
Ok, do you guys know of any vehicles that I could say....find in a junkyard that would have the same springs on it that a wagoneer came with stock? I know a lot of the parts on a wagoneer are sourced from other cars and even other car companys. For example I know my steering column is GM. Buying new springs is gonna be high would be nice to get them out of a jukyard.
Old 06-15-2017, 12:57 AM
ZackN920's Avatar
ZackN920 ZackN920 is offline
Springs that are the same, arn't one of them parts!
AMC 360, TF727, NP229, 3.31gears
rusty-rusty-rusty
The other's
1987 Dodge Dakota LE 3.9,A999TF,3.90gears(DD)
1994 GMC 'Burban L05-5.7,4L60E,3.73gears(DD)
2001 Jeep Cherokee Sport 4.0,AW4,3.73gears(limbo)178K
Old 06-15-2017, 07:00 AM
Well that sucks. Hopefully I can find a wagoneer in a jumkyard somewhere today. Thanks for the help guys.
Old 06-16-2017, 09:13 AM
Just so you know. J truck springs will fit also--just a little stiffer.
Old 06-17-2017, 01:52 AM
ZackN920's Avatar
Wouldn't the rear j-truck springs make the back of a wagon sit up higher? Pick-ups are commonly set up like that, so I would think so, but honestly idk...
rusty-rusty-rusty
The other's
Old 06-19-2017, 09:05 AM
Probesport's Avatar
Probesport Probesport is offline
I don't know your area, but usually you can find a spring shop that will do whatever style springs you need. Building leaf springs is super common and still a decent industry. Look for a spring and axle shop in your area and give them a ring, You may be surprised at the prices - they really arent that bad usually.
Ken S.
Jeep toy: 1988 Jeep Grand Wagoneer
Megasquirt EFI
: Heated Seats : Blower fix : Driving light brackets : Shorty headers
Prior Jeeps: 1997 Jeep Wrangler TJ, 1994 Jeep Grand Cherokee Limited
Other toys: 1930 Model A (Hotrod), 1997 Ford Probe Turbo, 2000 Jaguar XJ8, 2005 VW Touareg
1" front lift shackles + 4" front lift + 6" rear lift = poor caster angle? DanHS Off-Road FSJ Tech 4 09-26-2013 04:15 PM
4" lift springs + bj's lift shackles = smoother ride vs. stock shackles? high desert hauler Off-Road FSJ Tech 2 07-26-2013 08:33 PM
Lift Questions Kirk Off-Road FSJ Tech 7 01-30-2013 07:36 PM
Family Wagon Lift Question MoppTopp General FSJ Tech 13 09-19-2007 09:11 PM
I want 5" lift...how to do it??? rockcandy General FSJ Tech 4 02-22-2004 02:26 PM
