Today I noticed that the hose on my air injection system were cracked at the check valve.
So I pulled off the check valves to test them and there's barely any restriction in them. Should I be able to blow freely on both ends? Aren't they supposed to have a valve that restricts pressure from the exhaust?
Futhermore, where can I get a good price on oe Sillicone tubes to match the stock system? I'm kind of shocked that I can't find them. Also, grandwagoneer has them for $50 and it's straight tube. I could use copper 90' fitting to bend it, but then again, it's blue and I just want the stock tubes.
Any ideas? Thanks guys!
