Old 11-24-2019, 09:27 AM
87TPIYJ 87TPIYJ is offline
Originally Posted by JeepsAndGuns
I am still around. Just PM me your email address and I will send them over.
I sent them over. I completed and tweaked the file you sent me let me know if you want what I did. Thanks again.
Old 12-01-2019, 07:26 AM
JeepsAndGuns's Avatar
What did you do to them, add the holes for the knuckle/spindle? I never did have the ability to do that to the files. I did not know the exact clocking of the bolt pattern (since it is no symmetrical) and once I got it done (by hand) I had no way to add it to the files. Same thing with the exact location of the caliper mounting holes. (added after they were cut and mounted, but no way to add them to the files).
Have you done this mod to your axle too? I sent out the files to a few people, but never knew if anyone else ever did it.
Old 12-01-2019, 07:48 AM
Got a little bored and did a little looking online.
Looks like a couple places have started making their own version of this idea.
Gives people the option if they do not have access to a laser cutter business to cut these plates out and make a "home brew" like I did.
https://shopspeedhouse.com/parts/spe...-dmax-kit.html
https://torqmotorsports.com/product/...rake-brackets/
Old 12-01-2019, 09:15 AM
Yes I added the spindle holes and 1/2” holes for the caliper tabs. I used 1/2” rod as dowels and welded them together. I would post pics but it says max file size is 19kb.
Dana 60 full-floating/Dana 60 semi-floating cherokee83 General FSJ Discussion 33 09-12-2009 12:11 PM
FSJ VS FORD Rear dana 60 ??? jeepsohigh General FSJ Tech 4 08-17-2009 05:43 PM
Dana 60 question (conversion) L. Vargas General FSJ Tech 5 01-31-2003 06:15 AM
Dana 60 6bolt hub conversion? crazyguy General FSJ Tech 4 01-17-2003 03:05 AM
Ford Dana 60 bentpushrod General FSJ Tech 6 11-11-2001 07:32 AM
