Hi All.
New here, great forum.
OK, brief history of the truck.
87 Gwag I picked up a few years ago from a guy who brought it out to Mass from California. Very clean. No rust.
Had brakes when I bought it, and drove it home.
After buying (late fall period), the rear brake line (hard line) let go, and the vehicle sat outside until spring, since I had something else in the garage I couldn't move.
So far I have replaced the following:
Master cylinder, Brake Booster, Proportioning valve, front and rear hard lines, hard lines from master cyl to Prop valve, front and rear rubber lines, front calipers, rear wheel cylinders and linings, as well as rear adjusters........ pretty much everything. The reason being most everything was either 87 vintage, or broke while going through the system.
Now, no matter the sequence ( bleeding), I can get no pressure on the brake pedal while the truck is running. The pedal can be pushed to the floor with no resistance. With the truck off, I have a firm pedal (meaning the pedal only goes down only a inch or so at most).
This truck has the proportioning valve that pulls out. I have read the Hanes manual about bleeding the system, and that book makes no mention of even touching that valve during bleeding. I haven't looked at a Chiltons...if one exists for this truck, but I do know from talking to people, seeing it in forums, and other how-to's on the net, that the valve should be opened for bleeding one way or another.
What's the sequence though, is the question. I've done bleeding with the valve opened for all 4, since I thought that was right, but reading other entries here, I see that may not be right.
Is it valve closed for the rear, and opened only for the front? Or is it the other way? Additionally, the other unknown, is if I'm sucking air somewhere I'm not aware of. No puddles or visable leaks though
I've bleed the old way with someone pumping the brake, vacume bleeding, and speed bleeders, all with no luck.
I have the correct bleeding sequence: RR,LR,RF,LF. (far to close)
Any ideas? this is driving me nuts. I've been on this for almost a month...seriously. Somethings wrong with what I'm doing...just not sure what it is.
Would appreciate any ideas or input.
Thanks!
Thanks!
