Mikel,
I recently have been wading back in the mess of ebay. I have seen a lot of early parts listed. Do you have a OEM part number for it? I have a parts manual here. If we could identify it I could hopefully find the correct part number for it. Then you could google it every day till something surfaces. I am confident you could find it that way.
Al
Melford1972 says...
I make wag parts
1969 CJ-5 41 years owned
1968 M715 restomod
2001 Dodge 3500
2002 Toyota Tundra
Hi Al,
I don't have a PN, but I'm sure Kaiser didn't create a special switch for this application. I bet there are many other vehicles that use it.
Thank you.
Is it the typical plastic two part assembly? The turn signal arm screws into one of the pieces? That has the wires that go down the column about 2 feet to a plug?
Here is what I found...
Taken from volume 1 J series Parts catalog F-76073 R3 1962 through 1973
Switch, Directional Signal
All LHD (left hand drive) 8121438
All 232,258,304,327,350,360 1972 and prior
(Including hazard warning) 948847
All 230,232,327 1971 and prior (less hazard warning) 933849
WAG 327,350 941975 I think this is for the tilt column in an X model
All 258, RHD (right hand drive) 948847
Thats all I know
Melford1972 says...
I make wag parts
1968 M715 restomod
2001 Dodge 3500
2002 Toyota Tundra
International mail order company, specializes in replacement parts, literature, technical publications for Willys Jeep Vehicles both civilian and military from 1941-64
Melford1972 says...
I make wag parts
1968 M715 restomod
2001 Dodge 3500
2002 Toyota Tundra
Just to add some info, that sure looks a lot like the one I just pulled out of my '65. One of the plastic actuating arms broke off, I'm going to attempt to repair mine.....
Edit: That part number works!
I found this guy on eBay, he has the part I need, and it's available!
