Old 09-07-2018, 11:49 PM
badaboom's Avatar
badaboom badaboom is offline
Electric issue with headlights on
Well I have most everything light wise working although I have one issue that seems it would be a simple issue that's causing nothing but problems
headlights off All turn signal brake lights etc function correctly.
except the front parking lights won't blink
Turn the headlights on and the turn signals and hazard lights will not function. All of them
Also any help on wiring in the floor high low dimmer relay switch would be greatly appreciated.
I know from schematics there are two gray and one red wire 16 gauge.
gray H gray L red is power most probably
I see them from the engine well firewall side dandy to fuse block.
But over on the other side of the fuse block inside the cab I can't find JACK and any corresponding hook ups to the floor H/L dimmer switch.
Any help or good diagrams references appreciated.
Something is drawing current
thanks
Working on vehicle noted below
1981 Jeep J10 Laredo, 401-V8, 625 Carter, Lunati 262/268, Edelbrock Performer, MSD Ign., Hydroboost, Hyd. Clutch, Flow Cooler WP, Be Cool Aluminum Radiator, Doug Thorley, NV4500 5-Spd, NP-231D, 3.73 F/R Trac-Locs, Rustys 4" Lift, Vintage Red Metallic, Black Interior and 33X10.50X15 BFG, FiTech400 to come - IN PROCESS Bling Bling Cha-Ching
Old 09-08-2018, 04:53 PM
nograin's Avatar
nograin nograin is offline
My guess is a ground or hot is crossed somewhere. Somewhere being in the turn signal circuit. The headlights and parking lights each get power from different sources. So its not lightly related to the dimmer or headlights.
Power to the headlight switch for the headlights comes directly from the main splice. That wire is hot at all times. Circuit breaker is inside the switch.
Not sure what you're looking for help on regarding the wires themselves.
There's a fuse for hazzard/clock and brake lights.
A seperate fuse for directionals.
And a third one for parking lights on all four corners.
'85 Grand Wagoneer
360 727auto, NP229
body by beer (PO)
carries wood inside
no "wood" outside
My other car is a fish
Old 09-08-2018, 07:38 PM
Tripwire's Avatar
Tripwire Tripwire is offline
I vote for the ground problem as well - look at the schematics and hunt down the ground connections
trip
Abort? Retry? Ignore? >
NO headlights!! 87 WAG chris_N_NC General FSJ Tech 23 03-30-2011 03:05 AM
electric fan question Chief Gunner General FSJ Tech 9 06-30-2010 07:17 AM
New 2150 electric choke wire. Hafness General FSJ Tech 3 10-15-2009 05:43 AM
Electric choke on a '76 jode General FSJ Tech 1 02-14-2004 11:38 AM
Electric Lock Fix - Cheap and Easy mahlmann Electrical 2 07-11-2000 03:02 AM
