Old 08-28-2017, 04:17 AM
cma's Avatar
cma cma is offline
Dual Exhaust
guys, let me see your projects for dual end pipe exhaus systems.
Want to do one....
Markus!
Picture story:
Old 08-28-2017, 10:07 AM
Markus, what's your goal? Looks or performance? Dual exit chrome slip-on tail pipe tips can be had after market or a muffler shop can make you one from exh tubing cheap. For performance I would go with a full dual exh system (with a balance/crossover "H" pipe installed as close to the exh manifolds as possible. I would plumb both the exh pipes down the right side (stock location) of a Wag. A lot cleaner and cheaper than routing the left side past the fuel tank. I would go with 2 1/4 or 2 1/2 inch plumbing for true duals. Or cheaper/easier yet run a stock single exh configuration using 3" pipe. Any local muffler shop can fix you up.
my dual exhaust in the works NCOfab Street & Performance 9 03-31-2015 06:53 AM
If you were to convert to diesel getlost4x4 Diesel Swaps 56 08-25-2012 05:33 PM
J10 dual exhaust Dbay52 General FSJ Discussion 1 04-19-2010 08:46 AM
78 Wag dual exhaust routes FSJeep13 General FSJ Tech 6 03-23-2006 03:37 AM
Dual or single exhaust for my 360 swap? KYJ10 General FSJ Tech 83 10-05-2003 07:53 PM
