I am sure this has been covered, just looking for information. Is there and modifications needed to put the 4.0 intake onto the 258 head? I am not doing a 4.0 head conversion, I just rebuilt my head. I am converting to fuel injection with the harness etc and do not plan on running serpentine yet. Thanks everyone!
Jeep 258 to 4.0 conversion
You'll find way more information on other jeep forums vs. here.
It's well documented there, but very little info on this forum.
A google search provided a wealth of reading on the subject.
My nephew want to do the same @ some point with his 258.
Although it may get GM TBI first, and MPFI later?
Since his engine is basically all new, a 4.0 head swap isn't on the list.Tony
Thanks for the info, I will do some searching. I don't plan on the head swap either but I will be running mpfi.1983 Jeep Wagoneer-322,000 miles.
1972 Jeep Wagoneer-360-auto-sold
1988 Jeep Grand Wagoneer-One owner-64,000 original miles-Sold unfortunately
1968 Jeep Gladiator, full Resto in progress
1963 two door ifs one owner Wagoneer
If anyone else needs info I found a good right up at jeepers forum, it was the first result in the google search. From what I understand the only real modification needed to install the intake is new holes for the dowel pins in the head.1983 Jeep Wagoneer-322,000 miles.
Originally posted by yossarian19I understand that you just sunk money into the 258 head but I think you need to ask yourself "why aren't I building a stroker yet?"'85 CJ7 Laredo- Rebuilt 360, Tuned Port Injection, T-176, D300, W/T 3.31 w/Trac Loc, 31x10.5x15 BFGs
I think you're going to have a hard time putting the 4.0L MPFI intake on a 258 head without the recesses in the intake ports for the injectors. The 258 intake is just the square intake ports (been a while, going by memory here), while the 4.0L has little notched spots for the injectors.
Here's a comparison:
Geocities.ws - 404 Page Not Found! - Unlimited Free Web Hosting & The largest Geocities archive on the web!
The top is a Renix (if I remember right, been like 15 years) head, middle is a 4.0L (again Renix I think) intake, followed by a cast iron 258 intake on the bottom.
It's possible to do, and I'd definitely say throw it on and see how things look, but I think you're going to have problems with the injectors.
FWIW, you're REALLY limiting yourself by sticking with the 258 head, rebuilt or not. The 4.0L honestly is leaps and bounds better.
aa1983 J-10 - 4.6L(MPFI)/CS130D/Hydroboost/NV3550/D300/44/44/3.54/Disc-Disc/32s/42 gallon 'burb tank
My plan now is to buy a complete 4.0 and swap everything over at once. I currently have a 94 4.0 with the fabled 7120 head. I wont be completing the swap until February due to my time frame. I will be swapping over the head and intake with fi etc and keeping the block to build into a 4.6 stroker down the road.1983 Jeep Wagoneer-322,000 miles.
I found an extremely nice 81/82 ish J10 w/ matching shortbed topper kinda reasonable w/ 258 torn apart. I think it would be a perfect 93 and newer OBD2 4.0 swap would be awesome.
J20BP Drivetrain...........
775-537-7918
Yeah that would be a sweet swap. I love the 4.0?s, I like the 258?s but for everyday driving you can?t beat the 4.01983 Jeep Wagoneer-322,000 miles.
Originally posted by J20 projectI found an extremely nice 81/82 ish J10 w/ matching shortbed topper kinda reasonable w/ 258 torn apart. I think it would be a perfect 93 and newer OBD2 4.0 swap would be awesome.
J20
OBD2 is easier to read codes from and the codes themselves are more sophisticated / easier to diagnose. I don't think the sensor package changed any, at least until 2000 when they went coil on plug (no distributor) so aside from scan tools & codes, I don't know what OBD2 brings you. For me, those two are enough reason to go 96+ engine management (or megasquirt)
