I'm starting to get the itch to make another modification to my Jeep. I'm starting to research a front shackle reversal but I haven't found much information on this mod. I've read all the pros and cons and have a general idea of what is needed, however I haven't found any real good write-ups on do this to an FSJ.
I've read posts where people point to a kit made by T&J Performance Center, but it looks like they no longer offer one. (I've sent them an email looking for more information, but no response as of yet.) Does anyone else make a kit? I have a 4" Skyjacker spring lift on a HD44 axle from a J20 on the Chief with a drop pitman arm.
I'd like to get about an inch of lift out of the reversal and I'd be interested in best location of the front axle (front/aft). I'm leaning toward making this mod and then cutting and rotating my axle tubes to correct my pinion angle and caster. (Both are slightly off adding to a high speed vibration and less than optimal wheel centering.)
Any suggestions/opinions are desired at this point.
Thanks
Thanks
