Old 02-12-2013, 12:47 PM
smittles's Avatar
smittles smittles is offline
Smittles' 1964 panel Wagoneer
I figure its about time to do my reader's rig/build thread. I tried checking the rigs section'noticed they are closed.
I realized yesterday that I will have to remove the tranny and tcase to get my flywheel. I'm not thrilled, but I figure I will get new u-joints for the shafts when I put them back in too. I will update over the next few days as I get through the processes involved in starting the old Wag.
We are not in Kansas anymore and no, there are no ruby slippers here.
I got a few pictures yesterday from underneath.
Driver side view of the starter ring gear
Passenger side view of starter ring gear
Passenger front springs
Driver front Springs
Clutch slave cylinder rebuild/replace? or wait and see?
Smittles
'Max' 1964 Panel Wag 230/T90
1946 Willys CJ? "Hurricane"/3spd (T90?)
1979 Jeep CJ7 V8 (304?)/3spd (if no one else claims it)
'05 WK blue lawn ornament
'05 WK silver lawn ornament
'08 Patriot silver lawn ornament.
Old 02-12-2013, 02:12 PM
If the slave is ok and clutch works fine I'd leave it alone till needed. Hyd clutch parts are pretty much ignored for maint. If that's the case with yours(likely) I'd buy a spare before you need it so you're not down waiting for parts. Napa sells them made by United Brake Parts sold under the Napa label p/n 33721. They also sell a rebuild kit for the clutch MC p/n 434. They also sell the clutch MC but don't have the p/n for that.
Old 02-12-2013, 03:08 PM
serehill serehill is offline
Gone,Never Forgotten.
agree
They are usually maintained when the clutch dies. There's not a lot you can do without disassembly.
80 Cherokee
360 ci 727 with
Comp cams 270 h
NP208
Edlebrock performer intake
Holley 4180
Msd total multi spark.
4" rusty's springs
Old 02-12-2013, 03:47 PM
Flush/replace with fresh brake fluid yearly or at least every two years. Funky water logged brake fluid is tough on metal parts. Rust pits the bores and the loose rust destroys the rubber bits. Just remember to flush the clutch when you flush your brakes. Other than keeping clean fluid in the system really ain't no maint on the clutch...so do it.
Old 02-14-2013, 12:03 AM
I got the Willys....
If yours isn't leaking I'd leave it in there. My NAPA replacement started getting damp (not outright leaking) after about a year and a half.
It was only $35 though.
1971 Gladiator
Old 02-14-2013, 09:16 AM
FSJunkie's Avatar
FSJunkie FSJunkie is offline
The chassis looks good.
Those are some spindly little front leaf springs! Four-leaf? At first glance I thought they might be sagging because of the reverse arch they have compared to the slight upward arch the 7 leaf versions had by the late 60s. Of course, unless Jeep arched the 4 leaf packs more, they would naturally ride a little lower, so without a proper baseline, who knows?
Old 02-14-2013, 10:06 PM
Welcome to the land of empty pockets and unfinished projects...
Shes a beauty. This one is going to be fun to watch. Its also close enough I might get to see it.
46 cj2a
51 Willys p/u
'51 Willys Parkway Conversion
'74 CJ5
'75 J-20 Wrecker
'75 J-20 Cummins service bed
'77 J-10 p/u
'79 Cherokee
'88 Grand Wagoneer
Old 02-15-2013, 10:03 PM
66Stepside's Avatar
66Stepside 66Stepside is offline
Welcome, nice start to an awesome build!
1956 Willy Truck, Stock
1962 Fc170, 401, TH400/D20
1966 J3000, 401, T-18, D300
1967 Quadcab Thriftside Truck
1968 M715, 396, SM465, NP208
Old 02-16-2013, 09:45 PM
smittles's Avatar
Thank you, guys!
Unfortunately today I was forced to accept that I need a better work space...I need a lift...and a new wrench. I was also unfortunate to learn that the line from the master to slave(clutch) leaks. I think its just the old rubber. It didn't snap and hose me with fluid, but it obviously needs help. The transmission is being held (forward/backward) to the crossmember by 3 bolts that are not the right size and has slipped backwards a little(1/4 inch-if that). I am looking forward to visiting SEARS.
Is it safe to have the truck on 4 jack stands? I don't think it is, but I just don't want to die under it before I get a chance to wheel it. I would consider it if it was at least on a level surface...
I will see how the new wrench and/or socket works out then go from there.
Y'all have fun
Smittles
Old 02-16-2013, 09:55 PM
blkwarrior's Avatar
blkwarrior blkwarrior is offline
I figured you would have it running today . If you are on solid and mostly level ground jack stands are prety good. Mine lived on a set for about three months awaiting a heart transplant and TC swap. Keep wrenching at it man it will be running soon.... a WOT is only a request away .
1984 GW
360/727/208/ Edl 1406/ Custom exhaust
Future
Something Sweet with mean capabilities .
Old 02-17-2013, 06:05 AM
Originally Posted by smittles
...Is it safe to have the truck on 4 jack stands?...
Mine, like many others has lived in that position many times over the last 12 years, just like other rigs I have owned.
I don't enjoy the vision of being crushed so I always toss something under there when I have to be there. Spare tire, floor jack, it doesn't really matter as long as it's big, solid and will buy you enough time to get out from under there if something goes wrong.
I watched one of my rigs fall off jack stands.
I was bout 30 feet away and had just removed the front axle which involved the typical pounding and pushing.
It was a slow, almost graceful fall to the drivers side and I was really glad I was not under there.
Old 02-17-2013, 08:09 AM
Once I get it up, I grab a corner of the rig and shake the hell out of it just to be sure. If it moves any, I reposition the stands and do it again. As Tad says, if theres room, I through the tires under the frame area just to be safe.
46 cj2a
51 Willys p/u
'74 CJ5
'75 J-20 Wrecker
'77 J-10 p/u
'79 Cherokee
'88 Grand Wagoneer
Old 02-17-2013, 09:16 AM
Dang, I just looked at your spring pic's.
My old '70 front spring packs were up in PHX for well over a year waiting on a pick up that never happened.
I had left them with Mike (will e) for another member but he sold his rig.
They were re-arched to 4" at one point with a secondary main spring installed that eventually settled to about 2".
Might not be there because I did tell Mike to toss them, but it might be worth a PM to him, some of us have a very high hoarding factor when it comes to FSJ parts.
Old 02-17-2013, 03:40 PM
jsinajeep's Avatar
Oh, not me. I don't hoarder parts.
Old 02-17-2013, 08:43 PM
suzq044's Avatar
suzq044 suzq044 is offline
except that he was/is workin in a storage unit. They probably wouldn't look too kindly on having that sort of thing go on. LOL
Max²: 1964 Jeep Panel Wagoneer
Planning Stages
2018 Wagoneer Rendering if you're interested.
Old 11-04-2013, 10:40 PM
smittles's Avatar
Well, folks, I am long past due for updating. Sadly my father passed away at the end of March. I was in GA for most of April. I ended up deciding to move home due to all circumstances involved. I got home to find my 86 GW had been sold to a scrapper along with my 89 GW donor. I am down to 1-the 64 panel. Suzq and I moved throughout May. My granfather's CJ-7 and 64 Willys CJ are still here. Some backwoods country lowlife a-hole stole the radiators out of them a few months ago along with chevy late 70s pick up, 68 chevy fc van, and an rv in my grandmother's field. He also took any batteries available. Unfortunaley, I didn't find this out until weeks later. Still out of work. Now I need a transmission jack to work on the panel. Stalled until i find one in my father's estate or Santa brings me one for Christmas. I dont suppose we have many members near Macon, GA? Anyone in the area have a floor/low transmission jack I may borrow? Thanks again guys. Y'all take care.
Smittles
Old 11-05-2013, 11:44 AM
Sorry to hear about your dad, that's a tough one. Mine passed away last year.
Hang in there!
Old 02-20-2020, 12:41 PM
smittles's Avatar
Finally
Good afternoon y'all. Still in GA. Still havent fixed it yet. Have decided what to do with it. I'll save all the original parts and eventual do a resto. Been a rough cpl yrs regarding finances and transportation. For now, I'm in need of a driver. I'm starting to look for a newer drivetrain. Ideally, 4.0 and another manual. What is the most affordable vs performance engine and newest trans(rwd), and tcase(4wd) I can swap into this old 64? Thanks everyone!
Smittles
Old 02-20-2020, 01:50 PM
If an eventual resto is your end goal, why double the grief, work, costs with a drive train swap just to redo it over again later? What's wrong with your orig 230/T90/D20 that warrants replacing? The 230 isn't a hot rod or heavy hauler tow motor but if up to spec plenty quick for DD use. Granted the later 4.0 is a great I-6 but not a drop in motor. I don't know of any motor swap that'll be a drop-in. Yeah the 230 OHC has it's inherent maint issues but all cheap-n-easy stuff if you just keep up on the simple regular maint.
Old 02-21-2020, 12:56 PM
Pretty sure the 226 flathead Continental engine used in Utility Wagons is a drop-in for the 230 OHC. A good engine, but a big step down in power. And this would be a '50s era engine you'd need to find in good condition to replace your '60s era engine.
Wagoneer owners here in Montana are dangerous men! Hartman General FSJ Discussion 16 06-16-2011 10:28 PM
First wagoneer camping trip. MikeinColorado General FSJ Discussion 22 06-14-2011 11:40 AM
V-12 in a 1977 Wagoneer! Out of the Bill Harrah Collection after he died. H Callaway General FSJ Discussion 29 03-07-2007 06:17 AM
1964 2 door Wagoneer TPICherokee General FSJ Tech 10 03-17-2003 01:47 PM
