Old 02-01-2010, 04:49 PM
Crossbones's Avatar
Crossbones Crossbones is offline
Disk swap question , again
I have done much searching for information on this topic, and all I can find for a drum to disk swap is on 5 on 5.5 bolt pattern, but now that i have swapped my axles i need to do the swap on a 6 bolt pattern. Is there a write up that i'm missing somewhere? I know the topic has been brought up but I havent found any answers. If anyone could help me out even with a list of needed parts it would be very helpful.
Jeremy
1963 J-300 Thriftside
Old 02-01-2010, 07:00 PM
Cecil14's Avatar
Cecil14 Cecil14 is offline
We'll need some specifics on what axle you're wanting to put disks on now. If it's a standard open knuckle 6 luck D44 then disks are super easy. You can get the parts either from a junkyard or likely someone here in the for sale section. You'll need:
spindles
outer shafts
hubs
rotors
calipers
pads
splash shield/caliper bracket
Check out this page:
http://oljeep.com/gw/82_tsm/Part%202%20Section%20G.pdf
Page 38 has an exploded diagram of the D44 stock disk brakes.
aa
Old 02-01-2010, 07:44 PM
Highflyr's Avatar
Highflyr Highflyr is offline
great info Cecil! Been looking for the TSM!!
