This weekend I made new cargo area panels for my Cherokee. I used 3/16" wood paneling and foam insulation from Lowe's. I bought the foam sheet insulation that is aluminum on one side and plastic on the other and used it for a template. After triming down the foam for a good fit, I traced it on the back of the wood paneling and cut it with a jig saw. After I cut the panels I trimmed the foam down and attached it to the back of the panels with goop to reduce road noise. I spray painted them and attached the panels with velcro. Very easy job and it turned out great. You can't tell from the pic, but the panels are glossy and look like metal. Here are the pics.
Rear panels completed
Jon, that's exactly what I plan with my Chero! Looks good!Jeep Grounds
RRV Homepage
1987 Grand Wagoneer
AMC 360/TF727/NP229
1999 Wrangler Sport
4.0L/AX-15/NV231
?Freedom is never more than one generation away from extinction? by Ronald Reagan.
