Old 03-12-2007, 07:08 PM
baybilly's Avatar
baybilly baybilly is offline
Scorpion roller rockers on 401
has anybody used them on a 401. i did a search and see Walt had some good info on it as well as others. i'm dealing with the cast # 3216090-1 heads from a 72/73 401 with the screw in studs, not bridged rockers. i'm looking at the maddog racing push rod guide plates and the scorpion roller rockers at 1.6 for a valve train upgrade to go along with the rebuild. i had to go .030 on the bore, it didn't need that but i couldn't find .020 pistons with out breaking the bank with keith black. i went with 9.5 pistons.I'm having the block decked and sending the crank/ rods/ pistons/new balancer and new flex plate out to house of balance to make sure it's right. i'm still up in the air on my cam, so here's my Q's
1- are the maddog guide plates a bolt in with no mods?
2- are the scorpion rockers good for this set up?
3- will the stock valve covers still fit over the rockers?
4- any input on cams with this set up?
5- is their any way to stop this sickness, i'm picking up another one next week.
baybilly = dave
77 cherokee S ,parts
84 J10, parts
51 Willys
88 XJ, DD
1966 GT-350 mustang/ project
Old 03-13-2007, 07:21 AM
grimgaunt grimgaunt is offline
Location: close enuff to Denver, but far enuff from the people
I believe Tom Judd (jeepjake on this forum, but he hasnt been on here in years) did that to his 360. email him at coloradoarmory@yahoo.com
Old 03-13-2007, 11:02 AM
AMX factor's Avatar
AMX factor AMX factor is offline
Scorpions, Angus and CAT make great AMC rockers. My brother uses Angus I use CAT but have a set of Scorpions to go on a future motor.
If your heads don't have guide plates already you have to mill the pedestals to use them. Scorpions are fine. I think the factory vc's won't work but they might. The Edel chromes ($45) will work though. Depending on how much you mill off the deck and how big a cam grind you might have to go with custom cut pushrods. Cams I go with anything over a 268 advertised duration. On your balance job don't forget any pulleys that are bolted to that balancer.
"I'm sick of this sickness, don't touch me you'll get this."
1984 GWag "orphan" for sale
2 x 1975 Matador "murder machines"
1970 SST390 Javelin 10 yr project!
Old 03-13-2007, 04:13 PM
Walt's Avatar
Walt Walt is offline
I can't speak from experience on most of the questions, but stock valve covers should work fine. I don't see how the scorpions could be significantly taller than the crane energizers I'm running and I have heard that harland sharp clear factory covers as well.
Hold the valve cover in place by hand and turn the motor over with the starter to be sure.
I don't know how much you know about setting up valve trains, but don't learn the hard way like I did. Like amx factor mentioned, don't assume stock pushrodes will work.
90 G Wag.- New Motor/Trans/TC...Soon to have TBI!: CS-144 Alt; Parallel Flow A/C Condenser; Read this BEFORE you install an HEI ignition module!
Old 03-13-2007, 05:46 PM
jeepsr4ever's Avatar
www.Bulltear.com Chief
You dont need guideplates with those heads (3216090. Those rockers are a bolt in..you can use virtually any camshaft you want. Stock valve covers should work.
AMC/Jeep Forum
Old 03-13-2007, 05:59 PM
baybilly's Avatar
ya this will be my first valvetrain upgrade. i have always used stock in all my rebuilds in the past. so i now want to get up with the times and maybe make this 401 jump. so i will be picken you guys brains on help with this project. a big thanks in advance.
grimgaunt- thanks i'll shoot him a e-mail
AMX factor- thanks i'll be pm-ing you with some cam insights
Walt- thanks, you gave me some great advice on recurving my 360 dist and it worked fantastic. thanks for your help.
who says a old dog can't learn new tricks
baybilly = dave
84 J10, parts
51 Willys
88 XJ, DD
Old 03-13-2007, 06:28 PM
Hope you read my reply before you go and buy guideplates you dont need. 6090 heads have slots for single rockers and dont require guideplates.
AMC/Jeep Forum
Old 03-13-2007, 07:09 PM
baybilly's Avatar
thanks for the heads up. after you posted i went and pulled the valve cover of a 90 360 and i see the difference in the head where the push rod comes through a big round hole. my heads have the slot.is this the guide you are talking about? if this is the case i will have to stay with the same od pushrod as stock right. thanks
baybilly = dave
84 J10, parts
51 Willys
88 XJ, DD
Old 03-13-2007, 10:43 PM
dusty's Avatar
dusty dusty is offline
Cool
yes that is the slot matt is talking about. early heads have small slots dont need guide plates later heads 74/75-90 have big holes like the 90's you looked at.... think roller rockers and the pushrods walking around then think your heads small holes no room to walk around no worries.
AMC 401 supporter
GO UM Montana Griz
Old 03-14-2007, 04:36 AM
jeepfan93's Avatar
jeepfan93 jeepfan93 is offline
Not to highjack, but I would like info on recyrving the dizzy please.
Jeeps are Jeeps, keep Jeepin
>It's not about the ten hour drive to get the rust bucket jeep, it's about where your your going when it's done
87GW 99 Durango 5.2 drivetrain, SOA 35in Falken Wildpeak. MT rims
1997 Ram 1500 5.2 33in Falken Rocky Mounts for haulin
Old 03-14-2007, 07:26 AM
baybilly's Avatar
thanks guys one less thing to to worry about
here ya go lou
http://www.reincarnation-automotive.com/Duraspark_distributor_recurve_instructions_index.h tml
baybilly = dave
84 J10, parts
51 Willys
88 XJ, DD
