Old 01-18-2022, 06:52 PM
deckside deckside is offline
Oil pan gasket snap-ups + stud kit
Don't know if its overkill but was looking to use these Velcro snap cups and studs when I change out my oil pan gasket (need to replace dipstick guide). Anyone here use them?
.https://youtu.be/VKOWLO7f2Jk
1980 Wagoneer Limited "Prissyish"
Old 01-18-2022, 07:49 PM
Tripwire's Avatar
Tripwire Tripwire is offline
seems overkill to me....steve
Abort? Retry? Ignore? >
Old 01-18-2022, 08:21 PM
ok...i lol'd thru the video. shoulda had a dolled up woman with long nails using those things,woulda seemed more applicable....
Old 01-18-2022, 08:57 PM
SC/397's Avatar
SC/397 SC/397 is offline
Those might be kinda handy. I coat both sides of the gasket with RTV so that might help hold it in place a little better. The difficult part is sticking the rubber end seals up on the engine and hoping they stay there long enough to get the pan in place.
Obviously, it is much easier to do it with the engine out of the vehicle and upside down.
i
The Squeaky Wheel gets replaced in my world
Old 01-18-2022, 09:43 PM
So that's Ristow in the overkill column then?
Old 01-19-2022, 01:02 AM
for a 1-piece gasket they're included and handy.
worked like a charm when I did LT1 pan gasket.
for an old school amc pan setup LMAO
they'd chew the hell out of a cork gasket and be useless.
Old 01-28-2022, 11:10 AM
I have used zip ties to hold gaskets in place. Just lightly zip them in place and clip them off one by one as you start threading in the bolts.
I used dental floss on the exhaust manifold gaskets, too.
00 Baby Cherokee
Better timing cover gasket? Cronic leaking JeepsAndGuns General FSJ Tech 14 01-28-2016 10:56 PM
QT case to case gasket jeepersfsj General FSJ Tech 5 01-20-2012 05:13 AM
Manifold Flange gasket question JeepinMI General FSJ Tech 13 09-15-2011 07:16 PM
Bad carb base gasket in GP Sorensen kit from Autozone DanHS General FSJ Tech 2 08-17-2011 10:29 PM
aluminum axle gasket???? UnkleMunky General FSJ Tech 2 08-24-2001 04:47 PM
