Old 02-05-2012, 01:18 PM
scoffshore's Avatar
scoffshore scoffshore is offline
Alternator pulley removal - what's the secret??
So, I've got to change the alternator. Of course the Pulleys aren't the same, which I can completely understand. What's the dang secret for removing these pieces of junk? I've now got a Allen key poking through the inside of a socket using a pipe wrench on thd outside of the socket and another wrench on the outside of the Allen wrench, I've already bent a craftsman wrench on the Allen key........,There has got to be a simpler way!!!!!
1988 Grand Wagoneer -Stock-Dark Baltic Blue
1989 Grand Wagoneer -Stock-White-
Old 02-05-2012, 01:26 PM
sld's Avatar
sld sld is offline
Someone else just asked this and it didn't come off as I would have thought.
1981 WT Cherokee Chief /360/TF727/208/ Holley 600CFM/ Performer Intake/ Edelbrock headers/ Skip White HEI, switched dizzy gear. Patriot Side Pipes.
mrtazwrench's Avatar
mrtazwrench mrtazwrench is offline
On most of them I can hold the pulley by hand with a rag, and hit the nut with an air impact and they pop loose.
Chad
"Let's see that Red Blue Green **** sucker build one of these without duct taping it together!"
88Wag
87J20 Member, FSJ Prissy Restoration Association
83Cherokee WT
82J20
Parts vehicles: 1.5 Wags, 3.5 J20's, 1 J10 1 J300
serehill serehill is offline
Gone,Never Forgotten.
Impact wrench is the only way I've ever done it.
80 Cherokee
360 ci 727 with
Comp cams 270 h
NP208
Edlebrock performer intake
Holley 4180
Msd total multi spark.
4" rusty's springs
Old 02-05-2012, 01:27 PM
Rich88's Avatar
Rich88 Rich88 is offline
Try this...
First time I saw this done was at the auto parts store. After a little bit of , I brought the old one in with the pulley still on to have them transfer it to the new. All the guy did was put it on the floor in such a way as to put his sneakered foot against the pulley and using an electric impact wrench, the nut thing spun right off. A few years later, I did same myself. Twice in fact, except using an air impact wrench. Doesn't work if you try it slowly with a breaker bar. Apparently the nut needs the instant impact from the impact wrench to break free.
Old 02-05-2012, 01:28 PM
scoffshore's Avatar
Of course my compressor is fubared right now. I got it off the new one ok after u figured my setup out, but the old was is on tight!
Old 02-05-2012, 01:30 PM
FSJ Guy FSJ Guy is offline
X 3,000 on the impact. Or take it to muffler shop right before lunch. Offer $20 for them to swap pulleys for you.
Often the parts store where you bought the alternator will have an impact wrench for just this reason and they will be happy to help you out.
Ethan Brady
www.bigscaryjeep.com
Old 02-05-2012, 01:35 PM
sld's Avatar
sld sld is offline
OK, I did a search and it wasn't the alternator. However, I did find this site on the web.
Remove the alternator from the vehicle. The pulley should be attached to the alternator.
Read more: How to Remove a Pulley From an Alternator | eHow.com http://www.ehow.com/how_5752817_remo...#ixzz1lXP7q5k0 It seems as if the most important step is step #1, right after removing it from the vechicle, verify the pulley is attached to the alternator I suppose if it isn't attached, you can stop there on the flow chart.
Old 02-05-2012, 01:42 PM
Rich88's Avatar
Originally Posted by sld
However, I did find this site on the web.[left][color=#000000]Remove the alternator from the vehicle.
Jeez...Apparently this guy is an idiot or a clean-fingered engineer who never held a tool or tried his own advice.
Old 02-05-2012, 02:18 PM
scoffshore's Avatar
I wish it were that easy. Guess I'm going to have to wait for the other half to get back, or wait until tomorrow and just drive something else.
Bent a nice size wrench....
Old 02-05-2012, 03:03 PM
cherokees's Avatar
cherokees cherokees is offline
I recently ran into this myself,thinking it is some special nut of some sort. I took mine to a local alt shop. I thought they would have some machine that pressed it off. only to find they just beat the crap out of it with a hammer. The did it for free. Guy at the shop said the sleeve in the center has to be beat/pushed in first, then pulley can slide off.
76 Cherokee W/T,Quadratrac,AMC 360,Edelbrock carb and intake,TFI Ignition,CS-144.
Old 02-05-2012, 08:48 PM
firedriver firedriver is offline
Put an alt on my Wag about 2 weeks ago and I had no trouble switching the pulleys using an impact wrench.
Old 02-06-2012, 08:31 AM
j20brett's Avatar
j20brett j20brett is offline
360 AMC
That is correct. When i swapped in the cs144 Alt, the shop had to disassemble the brand new alternator, and proceed to wail on the tapered split sleave til it finally came loose. Ive never seen one taken apart before and im glad someone else did it for me.
Build Thread
Fight Crime...Shoot Back.
ΜΟΛΩΝ ΛΑΒΕ
Posting Pictures- Whats the Secret ? ozziewynot General FSJ Discussion 3 03-19-2011 05:00 AM
CS144 pulley removal - tapered collar type dakatl General FSJ Tech 6 12-13-2010 05:46 AM
pitman arm removal procedure Chuck Brown General FSJ Discussion 12 02-16-2009 11:41 AM
Flare removal question seamus General FSJ Tech 5 10-16-2008 09:48 AM
Windshield Removal Tad General FSJ Tech 29 10-24-2005 06:16 PM
