Old 12-29-2011, 11:41 PM
jeepskater433's Avatar
jeepskater433 jeepskater433 is offline
HEI Distributor
Looking to upgrade to an HEI distributor on my wag, anyone have any suggestions of whats a good one to go with without breaking the bank? I dont need the best of the best high end performance one, I just need something that isnt going to crap out on me and is reliable, thanks in advance for any input
CURRENTLY FSJLESS
Happiness is just a downshift away
2009 Ford Mustang GT-DD/Track Car
2006 Jeep Wrangler-DD/Trail Rig
1999 Jeep Wrangler-Dads Trail Rig
1989 Jeep Comanche-Project Truck
http://www.txfsja.org/forum/
Old 12-30-2011, 03:39 AM
sld's Avatar
sld sld is offline
Haven't put too many miles on my Skip White HEI. Cheap enough. Do a google search for AMC chewed distributor gears. You can not mis match the gears. I reused the gear from my old distributor onto my new HEI.
1981 WT Cherokee Chief /360/TF727/208/ Holley 600CFM/ Performer Intake/ Edelbrock headers/ Skip White HEI, switched dizzy gear. Patriot Side Pipes.
Old 12-30-2011, 06:05 AM
FSJ-Earl's Avatar
FSJ-Earl FSJ-Earl is offline
HEI from ZM Jeeps. One of the best swaps I ever did. It now has over 100K on the swap and have never had an issue.
FSJ-Earl
Old 12-30-2011, 06:17 AM
That is the Mallory brand. We have two and I am very happy with them.
Old 12-30-2011, 06:42 AM
kowboy84's Avatar
kowboy84 kowboy84 is offline
This is what I put in, You will have to drill it to put you gear on the end, not to hard, just pull the top off first so you can push the top all the way down.
http://www.jegs.com/i/JEGS+Performan...40020/10002/-1
Mine is a 1978 Wagoneer, It might be different then yours. Good Luck and Happy New Year
1978 Jeep Wagoneer is my DD, The only way you can stop me ,is buy it.AMC 360, AMC400, Dana300 Twin stick, lockers front and rear.
http://s326.photobucket.com/albums/k...oneer%20Build/
Old 12-30-2011, 07:00 AM
Dumpy's Avatar
Dumpy Dumpy is offline
I got an $80 eBay one and so far no issues.
Justin
'72 J2000 360 4bbl T18 D20
Old 12-30-2011, 10:14 AM
Jeepguy77's Avatar
Jeepguy77 Jeepguy77 is offline
I'm running the Mallory, the only problem so far was the original rotor was letting spark ground through it to the dizzy shaft. I put an msd rotor on it but the advance weights hit the inside of the rotor, and don't allow them to advance fully.
Pierce,
77 J10 454, TH400, D20,
Old 12-30-2011, 01:25 PM
Stupified's Avatar
Stupified Stupified is offline
I used the Skip White one off ebay with a new cam gear. Worked great.
73 Wagoneer 360 400/20 D40/D30 3.31
285/70R17 DuraGrapplers
post flipped rear, rough country 6110 chevy front AAL
Camo green Zombie Response Vehicle
Old 12-30-2011, 01:43 PM
If'n were me looking I'd go with Zack at Z&M.
Old 12-31-2011, 04:22 PM
scoffshore's Avatar
scoffshore scoffshore is offline
I second the jegs. Running great.
1988 Grand Wagoneer -Stock-Dark Baltic Blue
1989 Grand Wagoneer -Stock-White-
Replacing stock distributor with HEI distributor xuno_gil General FSJ Tech 7 07-07-2011 10:38 PM
Jeep Small Cap EFI distributor Woodchomper General FSJ Tech 20 03-11-2008 01:53 PM
Installation procedure for OEM dizzy Sgt Rock General FSJ Tech 25 09-09-2006 06:45 PM
