Old 08-01-2011, 01:03 PM
Blacksmith01's Avatar
Blacksmith01 Blacksmith01 is offline
A.I.R. removal
How had is it to get the bolts out of the manifolds to remove the A.I.R. system? I know that they are 9/16 bolts any one know what length to replace them with? The pipes have pin holes in them and the rest of the system is unhooked.
Every normal man must be tempted at times to spit on his hands, hoist the black flag, and begin to slit throats. H. L. Mencken
Gunner. Sabot. Sniper. Is not an appropriate use of ammunition.
Noli me tangere! - Old Guard 3rd US INF.
Old 08-01-2011, 01:59 PM
serehill serehill is offline
Gone,Never Forgotten.
Most of the time it's not easy .
You would need to soak them for a couple of days in PB blaster. They are hollow bolts & delicate. You might tap them with a hammer a few times to try & work them loose. If you do destroy them you can always mig weld them. I have an extra set that came off of my rig & the guy just took some vise grips & cut all the tubes about an inch above the manifold & double them over then smashed them flat with the vise grips. They never leaked. seams like the lowest risk solution.
Old 08-01-2011, 02:13 PM
I would liberally soak them with Kroil or P'Blaster a few times a day for a couple days before even messing with them. (WD40 is a joke get real penetrating oil). If they are seriously stuck the shock treatment of an air impact wrench is best to break them free w/o breaking them off. If that's not an option, use a quality box end and smack it with a hammer. Quick, sharp initial shock is key here if they're rusted in. Applying steadily increasing initial force will promote the chances of breaking them.
I don't remember the ideal length of the 9/16"NF replacement bolts to plug the holes but use a new or renewed copper washer when installing. The new bolts just need to be long enough to seal, not bottom out. On exhaust parts that deal with high heat I use copper based anti-sieze if you ever have to remove them.
Regular grey colored anti-sieze is better than nothing but will burn up after awhile. If grey is all that's available mix in a poof of graphite powder. When the never-sieze burns off the graphite remains and aids in bolt removal after it's been cooked repeatedly.
If you have neither just buy the copper based stuff cause by the time you buy the grey stuff and a tube of lock cyl graphite powder the cost is a wash.
Old 08-01-2011, 06:15 PM
I was thinking about pb and a BFH I could always heat them with the burner out of one of my forges. All I know is that they need to go. I'm waiting on my new transmission pan so it's the time to get this done.
Old 08-01-2011, 06:30 PM
scoffshore's Avatar
scoffshore scoffshore is offline
I don't know what size bolts they are, but team grand wagoneer has a full set of plugs for cheap.
1988 Grand Wagoneer -Stock-Dark Baltic Blue
1989 Grand Wagoneer -Stock-White-
Old 08-01-2011, 07:04 PM
Rich88's Avatar
Rich88 Rich88 is offline
I used 3/4" long bolts.
Old 08-02-2011, 08:41 AM
Cool I'll Pick some up
Old 08-02-2011, 02:44 PM
Whats the best way to get to the back bolt on the pass side? Take the heater off the firewall?
Old 08-02-2011, 02:56 PM
austinaubinoe's Avatar
I took them all off with a breaker bar.
Old 08-02-2011, 05:13 PM
With the heater box mounted on the firewall I don't think that I can get this last one. Is it just the two bolts that hold the box to the firewall?
Old 08-02-2011, 05:37 PM
asphaltrockdweller's Avatar
No there are nuts on the inside too.
Old 08-02-2011, 06:26 PM
Thank the God's that I don't have to move it. I got them busted lose and hit them with more PB. I'll mess with them tomorrow and get the new bolts in. I can't wait to drive this pig. We have named it Kenny.
Old 08-02-2011, 11:08 PM
FSJ Guy FSJ Guy is offline
Every time it runs out of gas or vapor locks, your passenger can look at you accusingly and shout "YOU KILLED KENNY!!!"
Ethan Brady
www.bigscaryjeep.com
Old 08-03-2011, 11:21 AM
FSJ GUY you got it. lol
CS144 pulley removal - tapered collar type dakatl General FSJ Tech 6 12-13-2010 05:46 AM
Power Steering Pump Pully Removal SnowShoe General FSJ Tech 17 05-20-2009 10:23 AM
pitman arm removal procedure Chuck Brown General FSJ Discussion 12 02-16-2009 11:41 AM
Flare removal question seamus General FSJ Tech 5 10-16-2008 09:48 AM
Windshield Removal Tad General FSJ Tech 29 10-24-2005 06:16 PM
