Old 01-18-2022, 10:47 AM
Wagoneer Taylor's Avatar
1978 401 Valve Springs Help
Hey guys,
For some reason I am having a heck of a time finding valve spring info.
More over, what is stock specs?
If anyone can point me in the right direction or let me know what you used?
I am building a completely stock 401 internally, but I would like to use dampened springs.
Thanks,
Taylor
Some call me Taylor...
Pewter, Blue Interior, Original 401
PO swapped in a 360, soon to be a 401 again!
"Soon" is a relative term.
Cracked cylinder put a hurt on me + bad connecting rods.
Old 01-19-2022, 09:16 AM
Cliff's Avatar
Cliff Cliff is offline
My 1981 Chilton's manual has valve spring specs for the 401 but only up to 1974. It's an "auto" manual so it doesn't include Jeeps, and 74 was the last year for the 401 in cars. But I can relay the 74 specs if you think it will be of any value.
Cliff Danley
1977 Cherokee S
Old 01-19-2022, 05:09 PM
Thanks Cliff, I am sure it couldnt hurt to have the specs on 74.
Please share.
Old 01-20-2022, 08:01 AM
SC/397's Avatar
SC/397 SC/397 is offline
You might be able to find it faster if you looked up valve springs for a 360.
The 360 and 401 use the same cylinder heads.
For a stock application, I usually buy these and eliminate the rotators.
https://www.ebay.com/itm/221346985073
I will see if I can find more info for you.
Old 01-20-2022, 09:06 AM
Hey SC/397, I should have reached out to you! You having built about a million on these.
Do you use or know of a set that has the damper in them but would be a nearly stock pressure?
I will look into 360 springs as you mentioned too
Old 01-20-2022, 09:09 AM
Another question, why do you eliminate the rotators?
Old 01-20-2022, 03:54 PM
SC/397's Avatar
I guess the main reasons I eliminate the rotocaps is because the early engines didn't have them and because it is harder to find the shorter springs.
Also, there is less of a problem with coil bind if you are using a slightly higher lift cam.
Old 01-21-2022, 11:54 AM
So the springs you sent in the link are longer then stock?
The problem I am having is I dont even know what size I should have in the first place?
I am running a stock cam.
Old 01-21-2022, 01:01 PM
Cliff's Avatar
I had mentioned that my Chilton's only included the 401 up to 1974, but I was wrong - it goes to 1976. Here are the specs:
outer spring test pressure 223 lbs @ 1.35"
spring installed height 1-13/16"
There is a separate spec for police engines:
intake 270 lbs @ 1.38"
exhaust 270 lbs @ 1.19"
The test pressure specs for 1976 360 CID are 213 lbs instead of 223, same height
Cliff Danley
1977 Cherokee S
Old 01-23-2022, 06:17 PM
SC/397's Avatar
Those specs look about right. 1.800" installed height and around 100# on the seat. I think the lighter ones may have been around 80# on the seat.
Old 01-24-2022, 02:04 PM
Thanks guys, this is helping me narrow it down at least.
Old 01-27-2022, 03:48 PM
Old 01-28-2022, 09:37 AM
I dont know whether to laugh hysterically or
I am going with laugh!
Old 01-30-2022, 11:15 AM
SC/397's Avatar
This is a really good How-to vid for you.
https://www.youtube.com/watch?v=oFX_Xq9WHTI
Old 02-17-2022, 02:19 PM
Old 02-17-2022, 02:22 PM
After talking with Comp Cams, they recommended PN 940-16
Max Lift:0.64
Installed Height:1.9
Coil Bind Height:1.2
O.D. of Outer:1.464
I.D. of Outer:1.07
Spring Style:Single
Spring Rate:241
Seat Pressure:93
Damper:Yes
This seems to match up with what you guys have listed above. Just need to check OD and ID specs.
Old 02-17-2022, 03:27 PM
Those are the springs I am running on mine.
Old 02-17-2022, 04:10 PM
Well Hey that makes me feel much better!
Did you buy retainers and locks as well?
744-16 and 603-16.
Old 02-17-2022, 06:09 PM
goldhammer's Avatar
Don't forget a decent set of seals either
Art
ASE Master Collision Tech
Old 02-22-2022, 09:08 AM
Any recommendations for seals?
Shimming valve springs 78J10honcho General FSJ Tech 5 08-23-2021 07:31 AM
Would valve covers from an 89 360 fit my 76 401? mattparliament General FSJ Tech 3 03-28-2012 04:49 PM
Do I need anything else with new valve springs? KYJ10 General FSJ Tech 4 03-16-2003 10:21 AM
Valve springs. jeepers General FSJ Tech 2 02-02-2003 10:36 AM
Replacement Leaf Springs ClarkGriswald Suspension and Steering 0 08-08-2000 03:49 PM
