  #141
Old 10-20-2012, 02:04 PM
Mars's Avatar
Mars Mars is offline
You and WHSII are really inspiring and I'm chomping at the bit to get going on my truck.
That's really starting to look awesome.
Mike
Wannabe Fabricator
Grumpy on a good day.
Old 10-20-2012, 02:15 PM
You're scaring the heck out of me.
I think I'll use lacquer.
Old 10-20-2012, 03:05 PM
Strode's Avatar
Strode Strode is offline
1st Chair, Cowbell
Thanks, Mars. I look forward to seeing your build thread.
LOL. Just remember: Your goal is to turn gray things yellow, then yellow things gray, then back again. And sand, sand, sand. It's therapeutic.
No, this is the stuff to use. Epoxy primer, 2K primer surfacer, and urethane enamel. The runs were operator error.
I've been taping reruns of American Hot Rod with Boyd Coddingtons shop. I've been paying special attention to the painters, and they make it look too durn easy. They don't even look like their paying attention to where the paint goes, they're just waving their hand with a gun in it.
I'm done with the wet sanding. Now I'm tearing all my plastic down and sweeping/blowing all the dust out. Then put new plastic up and hopefully shoot color tomorrow.
I'd try and get it in tonight, but I've been using water on the panels, and don't want to take a chance some water is hiding in a crack.
Ristow's Bunker
Old 10-22-2012, 11:10 PM
Strode's Avatar
1st Chair, Cowbell
Ok. Who said "experience is what you get after you need it"?
To recap: I spent all day Saturday sanding the whole entire body/fenders/hood/doors/tailgate. I thought about just sanding the few runs and sags, but I re-sanded it all. I even sanded thru the sealer coat, and hit some yellow 2K primer (cue the foreboding music....) I thought about putting down a new sealer coat, but decided against it. The paint will cover it.......
I cleaned out the garage again: Tore down the dusty primer plastic, blew out all the dust, put down new plastic, prepped everything for final color.
Here it is, ready to go. Pay attention to the telltale light primer spots. I wish I had...
Got up Sunday morning....Todays the day! Started spraying my color, and......problems.
My paint is a metallic pearl, and it is not covering. I can clearly see the light 2K primer showing thru. I painted everything one full pass, and started a 2nd one, and it wouldn't have mattered how many coats I put on, the lighter primer was showing.
I'd mixed a full liter of paint, so I kept painting the hood and tailgate, which didn't have any light spots. But my gun was acting up, and all I was getting was orange peel. I should have just quit.
I had to wait for the paint to harden to start sanding it.
So, I call my boss this morning and see if I can get today and tomorrow off, because the weather is changing.
We talk about this project, and I find out he used to paint cars professionally. Sweet! He says he'll come over and show me his tricks and how to set up my gun. I do good when it's good, but when something is wrong with the setup, I don't know which way to go to fix the problem.
So......I spend all day wetsanding the body/doors/fenders/hood/tailgate all over again today, for the 4th or 5th or 10th time. And I have an especially good time on the orange peel from Hades that I didn't have to put down, but I wanted to use the paint I had mixed. What an idiot (I think we need to call this emicon "The Painter" )
Here it is sanded again.
And I shoot what I hope is the final, final sealer coat on it. It goes on smooth, no troubles.
(Everybody tired at look at my Cherokee in various stages of primer? Welcome to my world)
So I'm be trying once again tomorrow. I wanted to do it all myself, but if I have to sand this thing again, I'm gonna lose it. So if my boss Justin feels like he wants to spray some, I'll be tickled to watch him. I feel alot better knowing a pro is coming over. I'm tired.
Ristow's Bunker
Old 10-22-2012, 11:20 PM
REDONE's Avatar
REDONE REDONE is offline
I envy you, no joke.
I love doing this and wish I had your facilities to do it in!
Here's to getting back that lawn chair in the middle of nowhere feeling!
79 J-10 - The Money Badger!
304/T18/D20/D44s
What's been did:
Holley 4160/Ede' S.P.2.P.
MSD Streetfire based TFI
Custom-hack gauge cluster
Razor swap
2 knob tape deck!
3" homebuilt lift
Half a hillbilly paint job
Old 10-23-2012, 04:23 AM
Strode's Avatar
1st Chair, Cowbell
Thanks, I'm very grateful to have a place like this to work. I like doing this work, I'm just tired of redoing it 3 times. I'm ready for the next step, you know what I mean? When it's finally in color, I'm never gonna be depressed about this resto again. And I'm walking away from it for awhile
I do like getting things straight, and after all this blocking, this thing is straight.
Ristow's Bunker
Old 10-23-2012, 10:27 PM
badaboom's Avatar
badaboom badaboom is offline
Keep after it your doing just want needs to happen - You will be more happy with the results.
1981 Jeep J10 Laredo, 401-V8, 625 Carter, Lunati 262/268, Edelbrock Performer, MSD Ign., Hydroboost, Hyd. Clutch, Flow Cooler WP, Be Cool Aluminum Radiator, Doug Thorley, NV4500 5-Spd, NP-231D, 3.73 F/R Trac-Locs, Rustys 4" Lift, Vintage Red Metallic, Black Interior and 33X10.50X15 BFG, FiTech400 to come - IN PROCESS Bling Bling Cha-Ching
Old 11-05-2012, 03:47 AM
Strode's Avatar
1st Chair, Cowbell
Well..........it didn't get painted.
Justin came over and he tried some panels. It turns out my final sealer coat wasn't as glass smooth as I needed it to be, and it needed sanding with 600 before the color. I should have reduced it alot more. And I found out where my spraying technique was bad with this metallic pearl color.
So because of that, and the fact that I want to do some striping, we decided it made more sense to paint it all in one shot, with the body on the frame and all the panels put on.
So we painted and cleared the rest of the jambs. I'll be sanding (SANDING!) some more, and it will be awhile now before I put final color on it. I want to get the drivetrain & exhaust all in before I put the body back on.
Ristow's Bunker
Old 11-05-2012, 03:56 AM
Strode's Avatar
1st Chair, Cowbell
I was going to keep the stock remote control mirrors. But since it wasn't getting painted soon, I decided to go ahead and try the Bronco mirror mod.
I ordered some 95 Bronco mirrors from Rock Auto. (Chinese.....sigh )
The power mirrors and the manuals were the same price, so I went power. I went to the junkyard and pulled a handful of power mirror controls and some pigtails for the mirrors.
I filled in the original holes.
Ristow's Bunker
Old 11-05-2012, 03:59 AM
Strode's Avatar
1st Chair, Cowbell
After I mocked up some mounting spots, I decided the base had the wrong angle, because it was putting the mirrors on at an angle. So I ground the outside lower edge of the mirrors away, and trimmed the base gasket.
Ristow's Bunker
Old 11-05-2012, 04:19 AM
Strode's Avatar
1st Chair, Cowbell
And then, for some reason known only to the defective synapses in my aging brain, I mounted them stupidly, with the ears pointing up. Exactly what I was trying to avoid.
(* I was going to post a picture of my FUBAR, but I'm looking at a picture of it now, and I'm still not able to deal with it. No picture of the FUBAR)
So, more welding and filling 3 good sized holes in the door. This is after my filling and a skim coat of filler.
I tried it again further up the door, and it came out ok. I don't think that grinding the base accomplished anything other than it allowed me to mount the mirror slightly below where some other people have mounted theirs. I did match the contour of the door a little. (This is a test fit without the base gasket)
Ristow's Bunker
Old 11-05-2012, 04:29 AM
Strode's Avatar
1st Chair, Cowbell
I guess I'll grind the other side the same way so they will match and mount it. I dunno if the grinding is worth it, and opposed to just mounting them right below the wing window like the pioneers before me did.
I'll be painting these body color.
Anyway, I'm trying to figure out the wiring on these power mirrors. The mirrors themselves have only 3 leads, up/down, in/out, and return. They reverse as the current is reversed.
The switches I grabbed have either 7 or 8 leads. I'm using an ohmmeter to try and figure out what is what, and it's confusing. I need to find a schematic of how the leads out of the switch hit the relay, and then the mirrors. I'm going to need some relays too, and I was looking around at the junkyard to see what would work. I don't know what else I'm going to need relays for.
Ristow's Bunker
Old 11-05-2012, 05:35 AM
cma's Avatar
cma cma is offline
Off Topic: where is this location? at your home? or did you rent any garage or old stock room?
i am looking forward to find a space but it is very difficult...
Markus!
Picture story:
Old 11-05-2012, 07:30 AM
Strode's Avatar
1st Chair, Cowbell
It's my garage at my house, which I'm very grateful to have.
Ristow's Bunker
Old 11-05-2012, 07:53 AM
CJ5 CJ5 is offline
Sorry about your troubles, Brad. I feel your pain. I am so glad I am done. Well, mostly, I still have the hood to sand the clear and re-clear.
It looks really good though. I went around the world figuring things out too. It is the nature of doing things ourselves.
How were your old mirrors? I may be interested in them if the black plastic trim is good. I used my old ones but could not refurbish the plastic trim very good.
Chief Laredo Build Album:http://www.fototime.com/inv/BB4AF31A10748CC
'72CJ - Complete Restore
'81SJ - Loredo Resto Project
'91YJ - Rock Crawler
Old 11-05-2012, 08:01 AM
Strode's Avatar
1st Chair, Cowbell
Let me get up in the attic, and I'll get a picture of them for you. You're welcome to have them. They'd be honored to be attached to your fine restoration.
Edit: They are in great shape, sent you a PM.
Ristow's Bunker
Old 11-05-2012, 09:14 AM
streetglide's Avatar
streetglide streetglide is offline
You have way more patience than I have on your project. Hence the reason I farmed out my paint job.
In the end, you'll have a greater sense of satisfaction knowing you done it all yourself.
Plus, I'm sure you saved way more money than what I spent on mine.
Wish I had the patience and knowledge you have to tackle a job like that. Cant wait to see the outcome...!
84 J20..Down to frame resto at the moment. http://www.ifsja.org/forums/vb/showthread.php?t=98908
69 Dodge Coronet(Super-wanna-Bee)
77 Dodge M880
Old 11-05-2012, 05:00 PM
Strode's Avatar
1st Chair, Cowbell
Glide, thanks. I'm really enjoying seeing the Money Pit come together.
Ristow's Bunker
Old 11-11-2012, 05:15 PM
Strode's Avatar
1st Chair, Cowbell
Did a little more work this weekend. I did the passenger side Bronco mirror, grinding the edges down again.
Ristow's Bunker
Old 11-11-2012, 05:22 PM
Strode's Avatar
1st Chair, Cowbell
I also primed the mirrors, and they will be body color.
I also put my steering column back together. I think I got it back together right.
Before:
After:
Ristow's Bunker
79 Cherokee Project- Finally posting build thread. scram-man General FSJ Discussion 13 08-24-2011 03:51 PM
1982 Jeep Cherokee Wide Track NOLAWALL General FSJ Tech 8 03-04-2011 09:46 PM
1978 Cherokee 4.0 build up Carl Rasmussen Off-Road FSJ Tech 36 01-21-2007 11:27 PM
What is a Cherokee Laredo? caionneach General FSJ Tech 15 12-30-2003 04:16 AM
