Old 09-29-2011, 07:55 AM
scoffshore's Avatar
scoffshore scoffshore is offline
Non-EGR Vac Diagram
Ok, I know its on here somewhere, but have tried the search function several times to no avail. I have been redoing my donor engine, and am finally getting close. We switched out to a performer intake non-egr, with a new edelbrock carb, and have removed the smog pump and the air injection system.
https://picasaweb.google.com/lh/phot...t=d irectlink
Now, we are trying to put it back together and want to make sure we have the vacuum system up right. I know somebody here has a copy of the minimal vac system diagram. Any help would be appreciated!
1988 Grand Wagoneer -Stock-Dark Baltic Blue
1989 Grand Wagoneer -Stock-White-
Old 09-29-2011, 01:36 PM
Walt's Avatar
Walt Walt is offline
I'm not exactly sure what you're looking for. The 'minimal' vac system is pretty simple... just draw a line from the carb to the distributor and another one to the brake booster and one to the PCV.
I'm not sure there are any formal diagrams other than the factory ones.
90 G Wag.- New Motor/Trans/TC...Soon to have TBI!: CS-144 Alt; Parallel Flow A/C Condenser; Read this BEFORE you install an HEI ignition module!
Old 09-29-2011, 01:41 PM
Don't forget manifold vac to the reservoir for your tcase and heat/def controls.
Old 09-29-2011, 02:37 PM
newtojeeps's Avatar
newtojeeps newtojeeps is offline
Did you put a regular cam in it? just curious the cam are built for all that smog %^^%.
Old 09-29-2011, 07:57 PM
scoffshore's Avatar
did not change the cam at this time. I know I'll regret it down the road, but budget just doesn't allow it. I want to make sure that my 4wd, heater controls, etc works. No reason to reinvent the wheel.
EGR and vacuum opinions please bilgamesh General FSJ Tech 12 04-13-2011 10:58 PM
EGR system pics needed! Please help! cavicatz24 General FSJ Tech 0 04-22-2010 08:59 PM
EGR - Rich or Lean? BarryL General FSJ Tech 15 12-20-2007 08:26 AM
Howell TBI and EGR? Hutti General FSJ Tech 17 01-31-2007 10:29 PM
Bad EGR valve? and carb tuning question. JeeperJay General FSJ Tech 3 07-12-2005 04:51 AM
