I am installing a stock, under dash, a/c unit in my J20...I plan to use a new style (smaller) pump, condenser, drier, etc...from one of the Hot Rod suppliers...Question: I would like to use R134 so do I need to replace the stock expansion valve assembly or can I use the old one?? I ask the question because I thought someone told me that the hose connections are different with R134...o-rings vs old style flared or tapered ends....any first hand experience out there???
A/C Question
I am currently finishing up my install and conversion. I replaced my expansion valve. It was only $11. Cheap insurance if you ask me. You need to replace the O rings, but there were no o rings at those connections on mine.76 Honcho 360/T-18 4 Speed/Dana 20
77 J-10 with 258/TH-400/Quadra trac
78 J-10 with 360/TH-400/Quadra trac (for parts)
Just remember if you have O-ring find some PGA oil or R-134A oil and lightly coat them this will help prevent leaks I also suggest to put small drop of oil on the threads of the fittings if they are compression this will help to guarantee a tight and leak free system.87' Grand Wagoneer
80' J10 4BT/AX-15/208
74' J10 Go Grabber Green Sold
Originally posted by Heavy_Metal_Thunder_81Inferior Chevy
So if the connections don't have o-rings now, they don't need to be replaced with new ones that do have them?? I will get a new expansion valve..sounds like a good idea but the hoses and everything else for the 134 conversion still confuses me....is there a good source for all the components to convert these old guys over??Charley
Originally posted by jeeperj20So if the connections don't have o-rings now, they don't need to be replaced with new ones that do have them?? I will get a new expansion valve..sounds like a good idea but the hoses and everything else for the 134 conversion still confuses me....is there a good source for all the components to convert these old guys over??
There seem to be guys on here that didnt swap anything, just converted and are ok. I dont have that kind of luck76 Honcho 360/T-18 4 Speed/Dana 20
