Oil pan replacement
  • CTGW
    • Jun 12, 2018
    • 49
    Oil pan replacement
    Hi,
    Is there a trick to getting the oil pan out? Is it straight forward? Mine is leaking and rusted through. Just hoping I dont have to pull the motor or something silly...
    1987 Grand Wagoneer
  • joe
    • Apr 28, 2000
    • 22392
    Naw, pretty easy. You might have to persuade it a bit with a rubber mallet or chunk of wood. I highly suggest jacking up the front end and supporting the frame rails so the axle hangs down for clearance. It's not a hard job but snaking the pan clear and out will be MESSY so have lots rags on hand.
    • CTGW
      • Jun 12, 2018
      • 49
      Ok, thanks. You're right. Wasn't too bad. Any suggestions on getting the old gasket off the block? Its like cement...
      1987 Grand Wagoneer
      • rang-a-stang
        • Oct 31, 2016
        • 5506
        I used a razor on mine, took a while, though.
        Chuck McTruck 71 J4000
        (Chuck McTruck Build Thread)
        00 Baby Cherokee
        • tgreese
          • May 29, 2003
          • 11682
          Professional gasket scraper on the block. Since you are replacing the pan, no need to clean it. Otherwise I would take it to the wire brush in the bench grinder. Make sure the sealing surface is straight around the bolt holes if you put a used pan back.
          • CTGW
            • Jun 12, 2018
            • 49
            So when installing the gasket, do I use some rtv at the corners? Is there a torque?
            1987 Grand Wagoneer
            • nograin
              • Dec 19, 2000
              • 2286
              I posted a couple pictures of removal way back when on my website.
              Just click on my screen name and select 'homepage'
              '85 Grand Wagoneer
              360 727auto, NP229
              body by beer (PO)
              carries wood inside
              no "wood" outside
              My other car is a fish
              • Ristow
                • Jan 20, 2006
                • 17292
                i spray all my gaskets with copper coat. use a little rtv at the corners. torque is light,snug them with a small ratchet. after a few hours retorque as the gaskets compress.
                Originally posted by Hankrod
                • tgreese
                  • May 29, 2003
                  • 11682
                  The Felpro box will tell you about RTV at the corners. The torque is given in the TSM.
                  • CTGW
                    • Jun 12, 2018
                    • 49
                    Ok, I got the stuff from teamgrandwagoneer. There were no instructions. I think I got it figured out.
                    Can anyone tell me the size of the exhaust studs at the bottom of the manifolds?
                    1987 Grand Wagoneer
                    • levelhead
                      • Nov 04, 2016
                      • 245
                      Do not use a cheap Chinese pan, they do not fit.....use a good OEM or American made (Mildonon) pan. Glue the gaskets and and seals on the block and use RTV on the seals and gaskets...light on the gaskets and more in the 4 corners. The glue will hold the gaskets/seals in place as you wrestle the pan in place.
                      1988 GW (2)
                      1980 Cherokee Laredo
                      1979 Wagoneer
                      1976 J10 401
                      1977 Wagoneer 401
                      1977 J10 4 speed
                      1969 J3000 (2)
                      1955 CJ3B
                      1964 Wagoneer
                      • CTGW
                        • Jun 12, 2018
                        • 49
                        Well, that may have been good advice. I finally got it all together and it leaks from the rear. Hope I didnt botch the rear main seal. I'm tired and dirty so I'm gonna investigate tomorrow.
                        1987 Grand Wagoneer
                        • CTGW
                          • Jun 12, 2018
                          • 49
                          Problem solved. Turns out I'm an idiot and didnt tighten the rear bolts on the pan very much. The deep lip on the stamped pan didn't allow the socket to get fully on the bolt. This is why I cant have nice things...
                          1987 Grand Wagoneer
