Old 03-14-2020, 05:36 PM
FLguthrie's Avatar
FLguthrie FLguthrie is offline
Exclamation Carb Flooding
I put a brand new carb 2150 on my 83 J10 360 4speed about 2 years ago, has been driving fine however this morning I was running a little late so I drove it harder than I had before 75mphish....
Anyway pulling into to work it kinda just died...thought ...... hhhmmmm never done that before, when I checked it the choke appeared closed so I thought that was it.....12hrs later after I got off found out gas was coming out the 2 top ports and front center port.....I blew it back with an air line and limped home not gettin on it, on my last turn...I opened it up and boom...flooding again...any insights?
Anthony
Old 03-14-2020, 06:07 PM
Who did the "brand new rebuild"? If it's a rebuilt bought from a parts chain store. It was rebuilt in Mexico. Actually just reassembled in MX. When they disassemble them for rebuilding/cleaning they save all the old decent parts and after cleaning reuse the old parts if they can. I'd guess your float is hanging up or the float needle is worn and not seating fully.
Old 03-14-2020, 08:38 PM
FLguthrie's Avatar
Carb Flooding
bought whole unit New from National Carb in Jacksonville, has always idled a little high but OK.
Old 03-14-2020, 09:49 PM
I'd still check the float system. Look for sinking float, damaged needle tip. Also look for crud deposits in the float bowl. Snot looking goop or sugary white hard deposits are prolly from E10 government gas gone bad. Hopefully it's just a worn needle tip cause those white E10 deposits are a bear to clean off.
Old 03-15-2020, 01:59 AM
FSJunkie's Avatar
FSJunkie FSJunkie is offline
Probably a sticking or binding float. They definitely should not do that.
Old 03-19-2020, 04:01 PM
FLguthrie's Avatar
Flooding
Thanks I plan on taking it apart tomorrow to check the float system however like I said I got it in stuck by blowing air through it to free the float and needle valve and I drove it home easily it worked just fine but when I got on it hard that's when it stuck to the accelerator pump be causing it to flood out also?
Thx
Old 03-19-2020, 05:09 PM
If it is "new" probably piss poor cheapnese copy.
I'd see about a return/refund.
A brand new carb. once dialed in should be problem free for years.
Opening it up will likely void any warranty.
If it's flooding out constantly you're gonna take a lot of life from your motor from being repeatedly flushed with gas.
If stuck with it buy a rebuild kit and replace the needle/seat, accel pump diaphragm etc.
I have seen a lot of bad opinions of the "new" cheapnese motorcraft carbs.
Old 03-20-2020, 07:34 AM
If gas was coming out of the bowl vents on top, that's unquestionably a stuck float.
I have found that the 2100/2150 float will stick open if the adjustment tang on the float is not perfectly perpendicular with the float valve. Float level is adjusted by bending the tang. You need to pay attention to this angle when you adjust the float. Possible your builder was sloppy or overlooked this issue.
Old 03-20-2020, 08:47 AM
79 Wolfpack 79 Wolfpack is offline
Trash entering the carb causing the float valve to hang open . When was the last time you changed the fuel filter ?
79 Cherokee wt
AMC high compression 401
t18 4speed
74 Cherokee nt plow
360 th400
Old 03-27-2020, 07:15 PM
I agree it may be filter (3 line in correct position?) or foam floats are sinking from fuel in your area.
Old 04-12-2020, 06:34 PM
FLguthrie's Avatar
Exclamation Flooding
Took it back to National Carb, they replaced the Power Valve, Cleaned it due to contamination and changed gaskets.. I can't remember if I had changed the Filters AND cleaned my tank before or after buying the Carb, I've changed 2 filters back then so now I've put a new filtering along with a CLEAR bowled filter ahead of the factory one to see if I am getting any contaminents.... Runs like a top now... National Carb here in Jacksonville was GREAT, 1 day service.
Thanks for responding
Trying to sort out vacuum on carb..Many pics of setup..for rough idle.. Eiffelxx General FSJ Tech 12 05-13-2009 09:48 PM
Carb questions+PO insanity! duncanstives General FSJ Tech 3 04-10-2009 08:48 PM
? about carb float L.D. General FSJ Tech 9 07-26-2004 02:44 AM
Simple carb Question olin18 General FSJ Tech 8 12-10-2002 07:24 AM
Rebuilt carb ----> Gas leak! (UPDATE) jode General FSJ Tech 15 11-25-2002 05:10 PM
