Old 08-07-2017, 03:49 PM
Old Ironsides's Avatar
Old Ironsides Old Ironsides is offline
What is the most reliable Ignition?
I installed a DUI ignition on The '76 17 years ago and it has performed flawlessly. So I decided to put the same on my '75 two years ago.
Since then, it has almost stranded me multiple times (I have a 160 mile commute 1-4 times a month). Each time it was the module. I've been through 5 of them in 7000 miles. Now it's doing it again, and I think I'll try replacing the coil.
I'm about ready to give up on it. I would love something that has no module to fail. Any ideas?
Cheers,
Grant
'76 J-10, 401 (1406/2131/DUI/RV Cam), TH400, Part Time, 3" lift, 33s, 346K Miles
'75 J-10, 360 (1406/2131/MSD), TH400 QT, 6" lift, 33s, 100K Miles
'77 Cherokee Chief, 401/Th400, QT, 4" lift... Totalled
Old 08-07-2017, 04:11 PM
I got the Willys....
I've driven Jeeps with points, HEI and DuraSpark. Points have hands down been the most reliable for me. They are extremely simple and parts are easy to get.
Quality ignition modules (for any system) are hard to get now a days. I had a BRAND NEW Echlin module bad out of the box, replacing a failed low mileage module that came in a rebuilt distributor. I'm running an NOS GM module now with no issues. Buy the best quality module you can.
1971 Gladiator
Old 08-07-2017, 06:48 PM
FSJunkie's Avatar
FSJunkie FSJunkie is offline
Points are very reliable if you know how to maintain them and the distributor. A worn out distributor will give you fits. Not many people know how to maintain points and their distributor properly any more.
The original Delcotron HEI is probably the most trouble-free and maintenance-free ignition for an old car. Some of the cheap Chinese aftermarket HEI's are junk.
Old 08-07-2017, 08:35 PM
I'm with the others. If you do the simple maint points are ultra reliable.
Old 08-07-2017, 08:52 PM
Tanker Tanker is offline
Points with MSD. Or just MSD.Ran MSD with points on a FE Bird ran a lot better an points lasted a long time.
Owner of Jakes FSJ Junkyard 91 Jeep Cherokee /2006 3500 Dodge AKA Babe the big blue puller
Hire the handicapped, they are fun watch!
Old 08-08-2017, 07:50 AM
Just points with no module... just a magneto like an airplane or lawn mower engine? Do points have a coil? Do these have a mechanical advance? What brand are you guys running?
Grant
Old 08-08-2017, 11:27 AM
Use points to trigger a MSD module. The points will last a looooong time, since all they do is trigger the module. The module takes over the stressful coil switching. If the module fails, you can disconnect it and run points ignition till a full repair is possible.
The OEM Delco distributors on these Jeeps are very good, as points distributors go. I think the Durasparks also are good, except for their terrible connectors ... maybe clip it off and replace with a Weatherpack. The aftermarket Duraspark modules seem pretty junky ... but you can run a HEI module or a MSD module with the Duraspark distro.
Old 08-08-2017, 05:06 PM
kansasboy001's Avatar
kansasboy001 kansasboy001 is offline
A little pricey but the msd distributior with an msd box and a oem ford tfi coil is a very solid system. The old non digital msd boxes are a little more reliable than the new digital ones too.
Old 08-08-2017, 06:17 PM
acct21's Avatar
acct21 acct21 is offline
I was having fits with the (what looked like the original) Duraspark ignition box. The aftermarket one from NAPA was DOA, so went ahead and replaced the ignition with an MSD (which with an adapter harness from MSD plugs directly into the Motorcraft distributor). Also switched over to the Ford E-core coil, big cap and new wires.
Starts and runs better, and no hiccups after a year.
Old 08-08-2017, 10:06 PM
SJTD SJTD is offline
I prefer compression ignition systems.
Sic friatur crustulum
Old 08-09-2017, 04:29 AM
bufurd's Avatar
bufurd bufurd is offline
That said my choice is a points dizzy with a Petronix unit in it, very reliable without the fiddling.
That's what's in Abner, Bufurd and Delta. All have been flawless.
Current fleet
07 JK Wife bought new...
Old 08-09-2017, 10:43 AM
NO6YHY NO6YHY is offline
Can points be used with a TFI coil, and will the spark be as strong? I'd hate to lose the benefits of the stronger spark with my TFI upgrade, but would like the reliability of points.
\"The General\"<br />1976 Cherokee Chief W/T 360<br />Carter AFB-9635<br />TFI... Done!<br />TH 400<br />Borg-Warner Quadratrac hi-lo & part-time<br />Dana 44\'s (3.54)<br />Flowmaster<br />*uva uvam vivendo varia fit*
Old 08-09-2017, 10:56 AM
That would not be my choice. It's probably ok, but the higher inductive kick from the hot coil might wear out the points faster. IDK.
The Duraspark module is just a big transistor that switches the coil. There is no spark enhancement going on inside the module. So the spark intensity will not be any different between the Duraspark module and points.
I was not suggesting running the TFI coil and points. However, the TFI coil combined with points and the MSD module would be fine. That's a spark upgrade - a longer, hotter spark - over just the TFI coil and Duraspark module.
Old 08-09-2017, 03:53 PM
Points are the most reliable and inherently emp hardened, but modern magnetic pick-up distributors are pretty reliable. Even the factory motorcraft worked perfectly for 30+ years with only needing 1 new cap. And the msd dist is built even better. True magnetic pick-up distributors are much more reliable than the pertronix conversion and close in reliability to points
Old 08-09-2017, 04:13 PM
Well, it's not the reliability of the distributor I'm worried about as much as the reliability of the ignition module. Using points lets me ditch the module.
Tgreese, you say you're not sure whether the TFI coil will be bad for the points, but you then say to use the points with MSD module and TFI coil. Does that not pose the same problem?
Maybe I should just change the module to MSD and not worry about points. But I've heard that even those go out.
Old 08-10-2017, 07:07 AM
Using the MSD box takes the load off of the points so you can then use the TFI coil. The points just tell the MSD box when to turn the coil on an off.
Thats why everyone is saying the points will last a very long time if you use an MSD box.
2004 Jeep Liberty
1998 Jeep ZJ 5.9
1994 Jeep ZJ I6
1989 Jeep Grand Wagoneer 360
Old 08-10-2017, 09:22 AM
... Does that not pose the same problem?...
No. With any module, the module receives a trigger from the distributor which commands the module to switch the coil. With points, the points themselves are the switch for the coil. An MSD module can accept a trigger from the points just like a trigger from a magnetic pickup. The module then switches the coil.
Old 08-10-2017, 10:23 AM
Got it. Thanks.
Old 08-10-2017, 12:19 PM
Oh! You mean like this:
http://www.foxnews.com/auto/2017/08/...e-in-2019.html
for the record, that was a rhetorical question. I knew you meant Diesels....
79 Cherokee Chief
Old 08-11-2017, 07:37 PM
serehill serehill is offline
Gone,Never Forgotten.
MSD distributor
MSD TFI coil
MSD 6A box
Set it & forget it. No Maintenance no points to maintain No load on the sensor. One & Done. Cheap, best system No brainer.
Can't afford the MSD Dizzy?
http://www.ebay.com/itm/Amc-Jeep-290...ZZR4ak&vxp=mtr
Find an MSD controller used on ebay or Criagslist. No maintenance simple the best
80 Cherokee
360 ci 727 with
Comp cams 270 h
NP208
Edlebrock performer intake
Holley 4180
Msd total multi spark.
4" rusty's springs
Ignition Switch/Cylinder trspeegle General FSJ Tech 2 07-02-2009 11:23 PM
Pertronix Ignition? 88sunroof General FSJ Tech 14 06-18-2009 08:12 PM
Help! Column shift ignition switch budojeepr General FSJ Tech 7 03-08-2009 07:54 PM
Simple and Most Reliable Ignition System for Howell EFI on 401 krek Fuel Injection 4 10-28-2008 09:41 AM
7 miles per gallon ?!?!?!?! jode General FSJ Tech 33 03-13-2004 02:32 AM
