Old 01-19-2012, 05:20 PM
mdill's Avatar
mdill mdill is offline
Gone. Not Forgotten.
Matched set belt group buy?
Gauging interest in doing a MATCHED set group buy on belts for the CS144 conversion.
Hardest part I have had to find is a matched set of belts, Gates no longer distributes belts in sets, My parts guy (CarQuest sells Gates belts) had to empty the warehouse, to come up with a set with matching date/plant codes.
Seeing if there is enough interest to get Gates or GoodYear to pull from a single production lot some belts.
The belt(s) would be either Goodyear GaterBack 13521's or Gates 7516's
(78->91 FSJ with CS144 and AC)
Home of ADHD project list
1977 J-10 Honcho 360-T15-D20
Old 01-19-2012, 10:00 PM
mrtazwrench's Avatar
mrtazwrench mrtazwrench is offline
I've had a few parts guys tell me, and not sure if I buy it, that after they go through a heat cycle they will shrink and size themselves, that's why no matched sets anymore.
Chad
"Let's see that Red Blue Green **** sucker build one of these without duct taping it together!"
88Wag
87J20 Member, FSJ Prissy Restoration Association
83Cherokee WT
82J20
Parts vehicles: 1.5 Wags, 3.5 J20's, 1 J10 1 J300
Old 01-19-2012, 11:19 PM
mdill's Avatar
Sounds good like a good story when selling what you have, not what the customer needs, run a tension guage on them it does not lie.
Old 01-19-2012, 11:38 PM
Rod2's Avatar
Rod2 Rod2 is offline
Bull! I've had my AC/alt belts on for 3+ years, they've been through many heat/cool cycles, and they still don't match.
Yeah, I'd love a matched set.
Rod Skaggs
'73 J4000 'WOOD GO' 360, 2100 MC, T-18, D-20, 60-2 rear, D-44 closed knuckle front, Eaton E-lockers both, Pertronix module, AC, PS, '77 Firebird tilt column, Hydro-boost, AirLift bags front and rear, 33x15 Goodyear MTR's, Pacer 15x8 aluminum Bullet Holes, Summit line lock, 3rd brake light
Old 01-20-2012, 03:28 AM
JeepWrencher JeepWrencher is offline
I had good luck with just getting two 52" belts of the same brand. My problem is the people working the counter at the local parts store don't know how to read belts (or anything else).
I only recently did my conversion so maybe I won't be as lucky the next time but I'll take my chances with the local parts store again.
Also, anyone that did or wants to do the CS-144 conversion, get MDill's bracket! Makes life alot easier than reusing the stocker.
Old 01-20-2012, 07:51 AM
Figured as much, I have access to a tension gauge at work but have not checked them yet.
Chad
88Wag
83Cherokee WT
82J20
Old 01-20-2012, 09:35 AM
GW Fisherman's Avatar
GW Fisherman GW Fisherman is offline
I went through 4 parts houses and finally got matched belts through Advanced Auto. I was able to take all the other belts back and it was by chance that they matched. One of the belts was from stock and the other was from stock out of Arizona. I had ordered them online. I ended up just ordering the cheapest belts they had. This was for a stock set up on my 89GW.
I would suggest ordering several belts at one time from a supplier, finding the two that match and return the others. May be the hard way but it worked for me.
2001 Subaru Outback 3.0 - Mamas assault vehicle
1989 Grand Wagoneer - DD and Boat Hauler
1985 Mercury 115hp inline 6 outboard
1989 Champion 184DCB - Bass boat
Old 01-20-2012, 11:33 AM
j10jim's Avatar
j10jim j10jim is offline
I would go for a matched set.
1980 J-10<br />Rusty\'s 4 inch lift<br />2 inch body lift,<br />35 in Xterrains on J20 axles<br />4:30 gears<br />Detroits<br />In-Cab cage thru the dash
Old 01-20-2012, 05:37 PM
Rich88's Avatar
Rich88 Rich88 is offline
Eventually the short one stretches and matches the longer one.
Belt routing and belt sizes, I think the previous owner messed up. RED-85-Z51 General FSJ Tech 6 01-06-2010 06:31 AM
Fan Belt Part Numbers The PIG Smith General FSJ Tech 0 11-21-2009 09:01 AM
Fan belt length? MeeBit General FSJ Tech 4 07-26-2009 07:27 PM
Registered Numbers So Far 2nd Day East Coast FSJ Invasion 50 06-02-2005 01:00 PM
A/C and belt question RottenDog General FSJ Tech 3 07-20-2004 02:56 PM
