Old 03-13-2011, 10:16 AM
Jacksons Hole's Avatar
Jacksons Hole Jacksons Hole is offline
Steering Column Compatibility
Most of my searches show GM steering columns work well with FSJ's. But I've also noticed most later-model FSJ's have the larger diameter column....and I have a '71 and (I think) a 2" column.
Long story short, I need to replace it (I've mentioned before it looks as if it roasted marshmallows and nothing electric works). What are the donor models I'm looking for to maintain decent location etc. I would also like to swap in a Jeep steering wheel regardless of column brand, so that would be a consideration. I have a floor shifter, so I don't need a column shift.
Ideally there's a direct bolt-in swap that has headlights/wipers etc on one arm so I can clean up the dash as well.
I'm also going to be adding the S-10 steering box to my manual steer truck (when I actually have an engine back in it running) - would you recommend any additional purchases, i.e. new steering shaft/u or rag joints? I do have play in my shaft now, so I figure at least rag joints would be key.
Thanks!
1971 J2000 Gladiator - "Bertha"
AMC 360 - 2bbl Motorcraft Carb - T-15A 3spd - D20 T-Case - 11" Clutch - D44 front and rear - 4.09 axle ratio
** Status - Scrapped **
1990 Grand Wagoneer
** New - Just learning about her **
steering column problems ForAmcJeeps General FSJ Tech 0 08-07-2008 07:44 PM
steering column compatibility question 78 cherk to 78 J10 Gambler68 General FSJ Tech 5 08-17-2006 05:59 PM
Advanced Steering column tech - wiring Sitting Bull General FSJ Tech 12 05-04-2006 04:40 PM
Steering column problems / steering shaft does not match new column Chrome General FSJ Tech 3 03-11-2006 09:33 AM
