I have a hard time starting my 77 Wag. I crank and crank and pump and pump to no avail. As soon as I add some gas to the carb. with a turkey baster it fires up and runs. So I checked the carb cold to see if the accelorator pump is working (new motorcraft from Holly) and see now visible signs of gas. Next I pulled the fuel line off the carb and turned over the motor to see if the fuel pump was working. No gas. While I was cranking it over to check this out the engine fired up and ran (with the fuel line off the carb and the truck cold). Shut down and replaced the fuel pump. Cranked it over and still no gas. When I bought the wag it had an after market electric pump in line down by the tank. I removed it right away to check it and it was frozen. ( the wag had been sitting for three years) Should I put a new electric back on or check the tank out first(hate to pull it if I can avoid it). I understand that the eccentric on the end of the cam may be worn. I don't really want the tear apart the front of the engine either. Any ideas? Thanks.
77 Wagoneer Limited
360 4v, QT, T400
77 Wagoneer Limited
360 4v, QT, T400
