Originally posted by Sambo
Rig Status, show us your pics and what you need to do for Cruces 2009
Originally posted by Gambler68congrats...that's the first post on here I have absolutely no effing clue how to comment on.
Originally posted by TadNeed to go through and find the short that took out my brake lights from the April trip...
Originally posted by Tad...refresh some basic stuff...
Originally posted by Tad...figure out the clunk/tweak noise coming from the left front when backing up at an angle...
Time to just break down and order some new ones.
Bushings are looking a bit ratty anyway, probably 1-2 more good runs in them.2000 Infinity QX4, 3.3L, MPFI, 4 speed auto, 2 speed Nissan tcase, Unibody, IFS front, 4 link rear solid axle with 255-70/16s
Originally posted by TadAnother bent front springFlint
Originally posted by fulsizjeepBummer - What is up with that? They just old and worn out?
I don't think these older springs can handle it anymore.
I'd love to go custom ($$) but it's gonna have to be some off the shelf 2" lift springs for the time being.2000 Infinity QX4, 3.3L, MPFI, 4 speed auto, 2 speed Nissan tcase, Unibody, IFS front, 4 link rear solid axle with 255-70/16s
ouchy Tad... it is always sumthin...
now trying for Ouray...
Las Cruces seems so far away at the moment.Flint
I'm close, if I can afford the gas and food!
Just need to finish my hydro assist steering:
Mounting ram right to the 3/8s thick cover and to a clamp collar for the tie rod I got from Ballistic Fab.81 Wagoneer 360/727/208, lockrite rear/welded front,4.10s, 7"SOA/shackle flip,3" body,OBA,37" Iroks,chopped,caged,highsteer,hydro assist....
I sure hope you can make it this year. Save up all your nickles and dimes.....it is worth the trip.
Here are some updates on mine. Just Hydraulic steering is left and a bunch of bs stuff.
1994 YJ
Amc 360
TF727
Stak 3 speed
44" Pitbull Rockers on Trailworthy H1's
Rockwells
76' Wagoneer
401....new project
Tow Rig Daily Driver// 2007 6.7 CTD Dually
Haven't done much to the chop-top in months. Except replace the hitch and x-member which got bent up last year during the rescue effort .
Putting in the D60 soon, that means swapping xfer cases (to passenger side drop for chevy 60) and new/modified exhaust. But if I had to, it could go today.'85 Grand Wagoneer "Caterpillar"
401, NV4500, 3/4 ton gear
'79 Cherokee "The Sandgorgon"
One Tons, SOA,T18 on 40's
78 J10 "Imoteb"
J20 running gear and axles
Well this is how she looked on the last trip out. Not much new besides the shoes.
Found this when I got home.
It looks worse in person, all the previous welds are cracked around the hanger.
I'll be removing all 4 front spring hangers and replacing them with some I make.
Not just as a repair, I'll be moving them so I can run the longer 74-91 front springs which flex better, are more common and cheaper.
For the time being I'm just going to beat it back into position and secure it with some small welds so I can do some local stuff.2000 Infinity QX4, 3.3L, MPFI, 4 speed auto, 2 speed Nissan tcase, Unibody, IFS front, 4 link rear solid axle with 255-70/16s
looooong way to go
thought i would post some progress
so far i have boxed the whole frame with an old bent frame that was on its way to the scrap yard
http://
mohawked the front and rear
http://
http://
welded the new centers in the H-1s
http://
put some tires together and threw them on one of the axles
http://
http://
only a few loose ends to tie up. like a rebuild on the trans, new drive shafts, the FI454, the pinion brakes, weld mounts for the full hydro steer, weld on spring hangers for the rear 63s, figure out a fuel tank, and build the front and rear antiwrap bars. you know little stuff like that ANYONE WANT TO HELP??
and before you ask NO that is not my new body lift. and that will not be my ride hightLast edited by mcjeep80; 07-27-2009, 06:22 PM.'80 WT.cherokee-tbi454/4l80/241c
welded rockwells/ PSC full hydro /3"body lift
front soa on 3" springs/inboarded 63s rear
42x15x16.5 TSLs on 8 bolt H-1s
'77 Honcho, 454/th400/div.205
3" body lift/3" of aal
35x12.5x16.5 thorn turds
DD/Tow rig, 2005 5.9 Cummins 3500 CC/LB
it will fit in the hole. not sure about the rockwell clearance. i will know more by tonight'80 WT.cherokee-tbi454/4l80/241c
