  #41
Old 10-17-2019, 05:44 PM
Originally Posted by pickledtoast
I'm not entirely confident in my initial waggy flexplate digitization. I will redo it when it all comes apart and remeasure. That said, I have about .175" difference between my '90 wagoneer flexplate starter ring gear and the ATP Z337 (XJ AW4) flexplate starter ring, with the waggy ring being further inside the bellhousing.
Again assuming it is accurate, you would need about a .275" spacer between the AW4 torque converter and the 360 flexplate, that's the method I'm planning on going with.
The bolt pattern on the AW4 torque converter is not even close to the 360 hole pattern, but the holes can be drilled.
Not sure why, but I can't see the pic. But, thanks for the info.
I might just go with balancing the aw4 flexplate like my 360.
Old 10-27-2019, 07:40 PM
The transmission cooler is falling apart so it's going to be replaced. Does anyone know the cooler width off hand? Hoping to use to OEM mounts/brackets.
UPDATE: Was able to measure...22.5" wide end to end.
Old 10-28-2019, 03:26 PM
gpcl16 gpcl16 is offline
Just curious why you want to keep your NP229 with this swap? If your AW4 came with a NV242 that would be superior transfer case in my opinion. Much more reliable torsen for the center diff instead of a VC, as well as a locked 4hi option, native bolt up to the AW4, and getting rid of the problematic vacuum shifter as well. Seems like a win win.
1988 Jeep Grand Wagoneer
4" BDS Suspension Lift
Tru-Trac Rear
Howell GM TBI with Custom Tune
Old 10-28-2019, 07:03 PM
My aw4 did not come with a transfer case. The NP229 does just fine for my needs... think family fun car with occasional snow usage. Also, converting to another transfer case seems to add more complexity to the swap, like linkage, speedometer, shifter ect. Keeping the NP229 may not be optimal, but the extra work to adapt the wagoneer to another transfer case just didn't seem worth it to me.
Old 10-29-2019, 08:01 AM
pickledtoast pickledtoast is online now
Similar reasons here for keeping the NP229. My vacuum shifter works well for now.
But...the vehicle speed signal for the TCU comes from the 242 VSS. I'm not sure yet how I will handle that. Originally I figured I'd just replace my speedometer with a not-cable driven unit, but I just fixed my cruise control and that gets it's speed signal from a speedometer cable in-line vss.
Either way I figure I will have to create a VSS, either for my cruise or for the TCU.
Old 10-29-2019, 09:17 AM
Looking into transmission coolers... I'm thinking of getting something in the 20k-26k BTU range. Is that overkill or not enough?
Old 10-29-2019, 09:23 AM
I could be wrong, but I think the VSS for the AW4 is near the output shaft of the AW4 and not the NP242. This might be different depending on the year. But, this would make sense to me based on the harness and transmission I have sitting in my garage. Technically, it's the trans output sensor.
Check out the pictures in this link.
https://www.cherokeeforum.com/f2/tra...cation-243436/
Old 11-01-2019, 09:22 AM
Overkill.
Plumb it through the radiator, for sure, and add a small cooler (think OEM sizing for a similar rig)
It's easy to go overboard here. What you want to remember is that a transmission has a designed operating temperature the same as an engine and that the lower tank of the radiator, lo and behold, is about that temperature.
Somebody chime in if they can show me wrong, but colder is not always better on a trans.
Old 11-01-2019, 06:35 PM
Originally Posted by yossarian19
Overkill.
Do you know what thread size the fitting is on the radiator?
Edit: seems like 1/4 npt... Will test. I've read the aw4 runs hot but could I just run it with the radiator cooler only? I do not plan on towing but do plan on many drives through the white mountains with camping gear which has some steep grades
Old Yesterday, 08:49 AM
Regarding Trans fluid temps, I bypass the radiator on all my vehicles because the engine is running at 195/210 degrees and the danger zone for a trans is 220. With a separate cooler of 24000 GVW they run at approximately 160-180 degrees and under heavy use approach 200. I dont live up north and dont need to concern myself with startup temps bellow zero but you can control the temps somewhat with a controlled aux' fan. It wouldnt turn on until after reaching a higher temp. Ive worked around hydraulics all my life and if any of it gets to hot to touch--its getting too hot.
Note: I had a 93 Ford with A4LD electronic trans and it would get hot and puke the fluid out during Off Roading. This left me stranded twice at the worst possible time. I resolved the issue by bypassing the radiator and it never did it again and the were no negative effects to running it cooler.
Old Today, 09:30 AM
Appreciate all the advice on coolers. I've leaning towards routing it through the rad and then to an external cooler, like the OEM setup. If it didn't get so cold where I live, which it often does, routing to just an external cooler would make sense just to keep things simple and get the lowest temps.
The AW4 I bought came with a Hayden 24K GVW cooler so that's what I'm using. Maybe overkill but I'm thinking with the bottom of the radiator temp at 180, the trans fluid temp might drop to 160 by the time it exits the external cooler. Operating range for the AW4 is 125-176 so this setup seems good.
Bought more parts.... mostly fittings, lines, and clamps. Will post some pics. So far, I've spent ~$650. Big items were the transmission ($200), wiring harness ($100), and spacer ($75). All the little stuff adds up quick! I'm sure buying a parts jeep would have been less costly, but there's no way I could have one in my yard and be happily married .
Jeep sat for 2 years, now has tranny problem jpekarek General FSJ Tech 15 02-15-2011 04:20 PM
TH400 to Manual Transmission Swap msh227 General FSJ Tech 9 08-30-2009 09:47 PM
79 chief Transmission swap nlrwrangler General FSJ Discussion 4 03-17-2008 07:39 AM
