Old 09-06-2003, 12:26 PM
cwisnoski's Avatar
cwisnoski cwisnoski is offline
OK the coursety light in the drivers footwell, and the one on the visor mirror work. And the cargo light switch will turn the drivers footwell light on. But no matter what I do neither the dome light or the cargo light work.
Any hints ?
I did pull the healiner down enough to see if they connections were good, and it all looked ok. Or should I just redo it for the sake of it ?
Is there something I missing ?
T.I.A.
Chris
87 Grand Wagoneer #projectbuddha
2012 JKU
Old 09-06-2003, 12:41 PM
Big Blue J-10 Big Blue J-10 is offline
Fuses?How about the bulbs them selves?
Adam
1980 Jeep J-10<br />AMC 360 (stock except some chrome)<br />Dual exhaust<br />Dana44 front AMC20 rear<br />4\" inch Trailmaster susp.lift<br />Chevy shackles front,extra leaf rear=5\"inches total lift for now<br />35x12.50 15(no fender triming)<br />body lift coming up soon<br />SOA not far off<br /><a href=\"http://www.fsjworld.com/BigBlueJ10/\" target=\"_blank\">\'80 J10 BigBlue</a><br />\"It\'s not that life\'s to short...<br />It\'s just that your dead for so long\"
Old 09-06-2003, 01:00 PM
andy d andy d is offline
Shade Tree Shaman
ill betcha the wire going up the b-pillar is corroded thru. this has happened to every wag ive had. its under the carpet under the drvrs seat belt reel. hardest part of the job is getting the reel unbolted. i just cut the wire back a few inches and butt splice in about a foot of new wire.
\'88 gwag,pure stock
Old 09-07-2003, 01:57 AM
Doug B.'s Avatar
Doug B. Doug B. is offline
I have the same problem in my '84 GW........
no running FSJ at this time......
Old 09-08-2003, 11:28 AM
jenmal jenmal is offline
Definately check that wiring like andy d said.I had the same problem in my 89 and it was the wiring on that side.
jenmal<br />88 GW 360 129K 4\" Mystery lift 33\"s<br />89 GW 360 135K Original Dana 44\'s<br />99 Grand cherokee 4.7 Rolled 4 times.Kept as souvenier<br />2000 Cherokee/4\" lift (Wife hates it)<br />[
Old 09-09-2003, 12:41 AM
tuckers89GW tuckers89GW is offline
yep, almost guarranty thats where the problem is.
