Old 05-18-2016, 06:51 PM
SmokinStanley's Avatar
SmokinStanley SmokinStanley is offline
J20 dome light wiring -- need help rebuilding
My new-to-me 1981 J20 has a two wire connector hanging from the dome light at the rear of the headliner, but the other half of this two-wire wire harness is missing. Where does the dome light on the J trucks normally get power and ground? I'm looking to use a length of 16-2 wire to restore the circuit. I have jamb switches, which both need to be replaced. For now, I'm curious about the 'factory' power supply for the dome light, and I'll worry about the jamb switches later.
'88 Waggy 167k, AMC 360, bone stock, just coming back to life after 7 years under a tree...
Old 05-19-2016, 08:21 AM
8man's Avatar
8man 8man is offline
Check the wiring diagram at Tom Collins Ol' Jeep. That will show you exactly what you are looking for. Good luck.
Brake Light Wiring.... 1968 J2000 68' Gladi8r General FSJ Tech 3 07-27-2015 11:06 PM
Dome Light Woes AJ's 83 WT General FSJ Tech 2 06-11-2006 05:03 PM
Map Dome Light -- Wiring as a rear light in Cherokee? rmorit01 General FSJ Tech 4 07-22-2005 09:14 AM
Dome Light & Cargo Light wont work. cwisnoski General FSJ Tech 5 09-09-2003 12:41 AM
