While I was cleaning up the interior of my GW I saw a thread about replacing the dome light with an LED. I picked up an LED and when I installed it all the courtesy lights stayed on all the time. I removed the LED dome and ran a wire across the connections and everything worked fine - I assume there is not enough resistance in the LED? Any suggestions how I fix this or what I can do? Do I need to go back to the original dome light and just add an LED bulb like this?
http://www.superbrightleds.com/cat/festoon/
