Old 01-18-2013, 02:38 PM
44BZ's Avatar
44BZ 44BZ is offline
dome light won't shut off
I decided to install the BJs replacement dome light I got for Christmas two years ago, which seemed simple enough. Two wires; one solid white, the other white/orange striped. I unplugged the two wires for the old light and plugged in the two wires for the new light and it worked!
However, it just stays on all the time. Since it wires into the headlight switch I figured it would turn on and off with the parking lamps or something. Unfortunately the light stays on when all the other lights are off.
The stock wiring is also one solid and one striped so I matched them initially. When the light wouldn't turn off, I switched them but no change. Any suggestions?
Old 01-18-2013, 02:51 PM
racegas racegas is offline
What about the dimmer knob?
'Robert E Lee'
89 GW White w/Cordovan Interior(daughter's DD)
Old 01-18-2013, 03:19 PM
serehill serehill is offline
Gone,Never Forgotten.
yep
Did you turn the headlight knob clockwise?
If yes then the wire is grounded somewhere or you have a bad door switch.
80 Cherokee
360 ci 727 with
Comp cams 270 h
NP208
Edlebrock performer intake
Holley 4180
Msd total multi spark.
4" rusty's springs
Old 01-18-2013, 03:21 PM
44BZ's Avatar
Originally Posted by serehill
Did you turn the headlight knob counter clockwise?
I didn't realize I had a dimmer function I'll check that and report back, thanks guys
Old 01-18-2013, 09:23 PM
44BZ's Avatar
Well for some reason the dome light won't come on now, but I discovered that I have working dash lights so it's kind of a win
Old 01-18-2013, 11:26 PM
KJ Ryu's Avatar
KJ Ryu KJ Ryu is offline
I just crank the dimmer back and forth til things work on mine.
Ron
2005 KJ, Hit-n-Run, 2am 6-17-2012, Totaled.
1977 J10, 2v304, T18, D20, 37x14s, SOA & SF on tons, still ugly Occasional driving!
1978 SJ Wagoneer, 360, QT, 33x12.5s, lift by Sawzall NOT Running
1977 J10 4v401, TH400, BW1339, mostly stock DD
Originally Posted by Mars
One man's trans leak is another's penetrating oil
Old 01-19-2013, 10:32 AM
Round 2
Clean the door switches or replace
80 Cherokee
360 ci 727 with
Comp cams 270 h
NP208
Holley 4180
4" rusty's springs
Old 01-19-2013, 03:35 PM
The PIG Smith's Avatar
King Browless
Bryan Smith
1982 J10: Stalled Project.
1981 J20: Commercial flat bed. Lost in Divorce
1987 J20 Pioneer: Former 'Ricbee' plow rig. RUST!!
Originally Posted by Jayrodoh
Originally Posted by Lindel
Old 01-19-2013, 09:00 PM
44BZ's Avatar
Mine doesn't have door switches that I can see. I think it's soley operated by the headlight switch. I messed with it again today for a little bit, but it's too cold outside and my fingers quickly became numb. My gauge lights still work, but not the dome light. I can't figure out what I did
Old 01-20-2013, 06:16 PM
Rich88's Avatar
Rich88 Rich88 is offline
If you don't have door switches then you should at least see the holes where they used to be and there may be wires dangling around inside there, one of which is touching ground that was keeping the light on. Just a theory. But possible. May want to fish around with a coat hanger bent into a hook at the end.
Old 01-20-2013, 06:47 PM
44BZ's Avatar
I wonder if the door switches were an option because I'm not sure that mine ever had them. There are what appear to be steel knockouts in the front door pillar. Perhaps the switches could be installed there? My TSM isn't clear about whether door switches were standard or not, more of an either/or kinda statement
Old 01-20-2013, 07:12 PM
Rich88's Avatar
Well, guess you got a case: No switches. Didn't realize something so cheap and simple would be an option. The original buyer must've really been a cheapskate. Umm...do you have ash trays?
Old 01-20-2013, 09:45 PM
44BZ's Avatar
Ha Ha. I do have those, on either side of my radio delete plate
Oil Pressure dash light + shut off + Auto meter oil pressure gauge blakeusa General FSJ Tech 0 10-23-2010 10:29 PM
Wagoneer Dome Light Help mtjeep General FSJ Tech 1 07-23-2010 10:03 AM
Dome light switch tabs broke Scott General FSJ Tech 3 02-06-2004 12:01 AM
Dome Light & Cargo Light wont work. cwisnoski General FSJ Tech 5 09-09-2003 12:41 AM
Dome light wiring behind dash? billyrb General FSJ Tech 7 05-05-2003 08:25 AM
