I spent the weekend under the GW rebuilding the OEM trailer wiring box electrics....new relays and fuse (both were a bear to find BTW). Well I hooked up the 7 pin to 4 converter to the trailer and my running lights work along the side of the trailer and right rear (not left) and neither brake or turn lights work. I hooked up my Bronco and the trailer lights are in good order just to check.
I didn't change any wiring simply unpluged the relays/fuse and reinstalled...any idea why only a portion of the lights work?
