Thread Tools Display Modes
Old 03-17-2007, 02:45 PM
CustomWag's Avatar
CustomWag CustomWag is offline
Rear Main Seal Leak ID
hi all, i'm Rick's son...he's doing the rms at home with no internet, so he asked me to ask: he's got all the oil pan bolts out, but the oil pan won't come loose. He's smacked it with a rubber mallet, looks like blue rtv across the front. Any suggestions how to get it loose?
he thought it would be bad to drive a screwdriver between the pan and the block, but maybe that's the only way? Any suggestions you have would be greatly appreciated thx much, anxiously awaiting replies
Rick
84 Custom GW
360/727/208/d44f/AMC20r/3:31
Manual windows/locks/seats
Last edited by Tad : 03-24-2007 at 08:04 AM. Reason: Title edited prior to archive
Old 03-17-2007, 02:49 PM
I got the Willys....
Smack it harder. If all the bolts are out that should be all it takes. I've had to hit pans pretty hard with a mallet to knock them loose.
1971 Gladiator
1968 Gladiator J3000 3406Z 160" wheel base DRW 350/T18
Old 03-17-2007, 02:59 PM
CustomWag's Avatar
should he stay with the mallet or can he switch to a BFH?
Rick
84 Custom GW
Old 03-17-2007, 03:01 PM
mrtazwrench's Avatar
mrtazwrench mrtazwrench is offline
I'd stick with a mallet or deadblow, BFH would bend up the sheetmetal pan pretty easy.
Chad
"Let's see that Red Blue Green **** sucker build one of these without duct taping it together!"
https://www.facebook.com/media/set/?...3&l=76427b95fd
88Wag
87J20 Member, FSJ Prissy Restoration Association
83Cherokee WT
82J20
Parts vehicles: 1.5 Wags, 3.5 J20's, 1 J10 1 J300
Old 03-17-2007, 03:05 PM
Ditto. What size amllet is he using? Maybe a larger onoe is order.
Could try a block of wood against the pan and hit that with a bfh. Shouldn't hurt the pan unless you hit it really hard.
1971 Gladiator
Old 03-17-2007, 03:14 PM
CustomWag's Avatar
gfh
ok, thx much. He's been whalin on it already, but he says he'll keep poundin away
Rick
84 Custom GW
Old 03-17-2007, 03:25 PM
CustomWag's Avatar
one more question; now that the starter is off, and he's got a good view underneath, it looks like the passenger side valve cover is leaking pretty badly. he's curious if it's possible that a valve cover leak can get as bad as an rms leak? because he's losing massive amounts of oil
Rick
84 Custom GW
Old 03-17-2007, 03:28 PM
yes they can! i've yet to have a "rear seal leak" actually be one!
the ends of the intake can dump copious amounts of oil too!
if it's a rms,the engine side of the flexplate will be covered in oil from the crank to the ring gear,and the inside of the bellhousing will have oil slung all over inside it.
is the starter nosecone FULL of oil?
Old 03-17-2007, 04:38 PM
CustomWag's Avatar
no, the nose cone was clean and dry
Rick
84 Custom GW
Old 03-17-2007, 04:44 PM
well,a seal leak will leak oil past the seal,to the crank flange,and the spinning crank/flexplate will sling it out down the frontside of the flexplate,and off the end of the ringgear,getting oil all over in there.
sounds to me like it is not the rear seal.
Old 03-17-2007, 05:16 PM
CustomWag's Avatar
my dad says thanks mike and all the rest of you guys, he's buttoning it back up, and gonna have another look-see later
Rick
84 Custom GW
Thread Tools
