I looked through some old posts about it, as well as the article in the tech section. My problem seems a little odd. The 360 in my Wag is stock, and I'm assuming never rebuilt, with 148K miles, recently rebuilt 2150 carb, and K&N filter.
I've mainly been driving it around town, with a little highway driving, and haven't had a problem with detonation using 87 octane. My girlfriend and I took a trip last weekend, and it started pinging when going uphill under load. I figured it was just because it was loaded down, so I used 91 octane and the ping went away.
After getting back and filling it up again with 87, it's still pinging around town (always under load, like uphill acceleration) on 87. It wasn't doing this before. I know the likely candidates are bad/leaky vacuum lines, EGR valve, CTOs, and worn distributor advance springs. What is the most likely candidate for it to start doing this so suddenly? I don't have a lot of time and money to just start throwing parts at it.
FYI, last I checked (about a month ago), the vac lines were all good and hooked up properly, with the exception of not having the charcoal canister lines hooked up since I'm waiting on a new can. I have the purge signal line plugged, and the vapor line near the PCV valve plugged. The bowl vent and tank lines are still hooked to the can.
Thoughts, guys? This sucks since my SVO is overheating (or has a bad gauge-planning to work on both of these this weekend).
