Trying to dial my timing in with the skills I have but I have none so how about some input from the fsj guru's. I see the tach input connection on the coil but that makes me wonder even more questions so my question is what type of tach do I need for tuning this rig and how do I use it.
What kind of tach do you have and how do you hook it up?
I am glad you asked this. I have been wondering what other people have been doing.78 Wagoneer, 401, Turbo400, QT, Posi Rear, 4" lift, 33X10.5 BFG
69 Gladiator, Buick 350, T18, 14B, 44HD, Cross-over HIgh Steer, Hydroboost, 6" Lift, QR78 Buckshots
63 CJ5, 302 Ford
Owner Buckstop Truckware, Inc
www.buckstop.biz
i have a cheapy sunpro, $30 and it is plenty accurate for my needs, made by snap on actually.... i just hooked mine up the the negative wire right at the coil1985 Grand Wagoneer-360/727/229/D44/AMC20
2011 Mazdaspeed 3
2012 Focus
2000 Camaro
1995 Mustang
2009 GSXR-600
I use a simple hand held dwell/tach. Have 1 for many years and another one that came in an Equus Tune Up Kit I bought at Harbor Freight. Sat for a long time until I got this Waggy. Simply connect battery clamp and coil (dist/-) clamp with an adapter - I use a paper clip - and thats it. I also block the wheels because 650 rpm in drive can override a weak/out of adjustment parking brake easy. On my 91 Montero I can access the computer trouble codes with the dwell/tach.Currently without
Formerly
1986 G.W. 360
1986 Eagle Wag
1985 G.W. 360
1984 Eagle Wag
1981 Wag 360
1978 Wag 401
1981 Cherk W/T 258
1966 Wag Super 327
Not counying XJs'.
[Did have a 94 & more recently a '97 GC with 5.2. for awhile. Just not the same! Now have the FSJ blues!
Originally posted by El_Diabloi have a cheapy sunpro, $30 and it is plenty accurate for my needs, made by snap on actually.... i just hooked mine up the the negative wire right at the coil
91G-Dub = Bill Houston
1979/1980 J-10 Junkyard Dog 258 4 speed D44 front AMC 20 rear 3.31 Lincoln Locker Status Running
1991 Grand Wagoneer Gray Ghost (bone stock) STATUS Gone but not forgotten
"The tree of liberty must be refreshed from time to time, with the blood of patriots and tyrants.
It is its natural manure."
Thomas Jefferson
I can attest to both tach solutions for tuning, either a cheap dash-mounted unit or a handheld tach/dwell meter. I prefer the handheld version because it's right in the engine bay and isn't permanent (I used to have a Sunpro tach in my '89 GW and it looked terribly out of place).
I go for the low cost Sunpro style as well. Actually bought a spare just for under hood work.
The regular one is mounted to the steering column just like most do (glove box works too though). The second one I fitted with alligator clips (from radio shack) on the power, ground, and signal wires so I can use it as a hand held unit under the hood.Mike Wood
Resident alien and thread killer!
