Old 04-23-2013, 03:46 PM
Mikel's Avatar
Mikel Mikel is offline
What I've been up to...
1969 M715 6x6
1963 J300 Swivel frame
Old 04-23-2013, 10:31 PM
44BZ's Avatar
44BZ 44BZ is offline
So what's it gonna be? Is it set up to swivel in the middle? I'm sure whatever you've got planned will be epic, just like the 6x6
Old 04-23-2013, 11:56 PM
Driftwood's Avatar
oooooh, what can it be for? Is the 6x6 going to be sold to make room for this project?
Old 04-24-2013, 05:06 AM
I find it interesting that I too have been working on such a project. I had a design much like yours but I couldn't commit myself to separating the frame near it's most loaded point. I am now building a touque limiting sub-frame instead.
Resistance is not futile yet.
Old 04-24-2013, 09:58 AM
Mikel's Avatar
Keep in mind that the swivel completely eliminates all torsional loads (articulation).
Got any photos of your setup?
1969 M715 6x6
Old 04-24-2013, 12:52 PM
Oolah10293's Avatar
Oolah10293 Oolah10293 is offline
Where is the driveshaft going to go?
Old 04-24-2013, 04:38 PM
Mikel's Avatar
Over the swivel.
1969 M715 6x6
Old 04-25-2013, 04:59 AM
This is what drew me to this design in the first place however it was dealing with the high bending moment in this area that I could not get comfortable with. It looks like you may have dealt with that issue. I suspect you intend to use this truck in a way that differs from mine. It looks like you have tapered roller bearings and a lock-out feature?
Other than parts for the assembly jig I have nothing tangible at this point.
Old 04-25-2013, 05:09 AM
Yes, this is what drew me to the design in the first place however it was dealing with the high vertical bending moment that I could not get comfortable with. It looks like you may have accommodated that issue. I suspect you intend to use this truck in a way that differes from mine.
Old 04-25-2013, 05:20 AM
Mikel's Avatar
I couldn't find tapered roller bearings small enough that had the necessary thrust and radia loading capacities, so I went with a combo of cylindrical needle roller bearings and thrust bearings. The cylindrical needle bearings have a static capacity of 65,000 lbs and the thrust bearings 55,000. If I lifted the (loaded) truck from the swivel, it would still be within the acceptable loading range. The entire assembly is sealed and will be filled with gear oil.
1969 M715 6x6
Old 04-25-2013, 07:42 AM
Looks interesting!
Old 04-25-2013, 10:27 AM
e_digg's Avatar
e_digg e_digg is offline
You are an engineering genius! I hope it doesn't look like this though!
1991 Grand Wagoneer
My 91 Phoenix Build Thread
Old 04-25-2013, 10:57 AM
austinaubinoe's Avatar
first thing that came to my mind:
http://en.wikipedia.org/wiki/Gama_Goat
Old 04-26-2013, 11:38 AM
e_digg's Avatar
I was actually thinking of this (below) but flipped on the joint axis for suspension purposes. I studied Mechanical Tech in college so I know what he is getting at. I however could never fabricate something like it!
1991 Grand Wagoneer
Old 04-28-2013, 12:21 AM
Is this going to be another 6X6?
Old 04-28-2013, 04:01 AM
Mikel's Avatar
No. It's going to be an M715 with a J cab.
1969 M715 6x6
Old 07-07-2013, 01:17 PM
Driftwood's Avatar
What's the latest?
Old 07-07-2013, 07:01 PM
FSJunkie's Avatar
FSJunkie FSJunkie is offline
It's going to be very interesting to see what engine torque will do to that frame.
Old 07-07-2013, 07:23 PM
I got the Willys....
I bet not much. I've seen it in person, it's a very stout frame!
1971 Gladiator
1968 Gladiator J3000 3406Z 160" wheel base DRW 350/T18
Old 07-07-2013, 07:25 PM
Mikel's Avatar
If anything, the swivel will dissipate all torsional stresses.
1969 M715 6x6
