  #41
Old 12-20-2010, 12:38 PM
chrisnsarah's Avatar
The craziest I ever saw was on a parts truck I bought (ok I got it for free). It had a 3" spring over lift using stacked pieces of 2 1/4" oak flooring as lift blocks in the front and rear. Since it appeared to be an abandoned project, I'm giving the PO the benefit of the doubt and assume it was a mockup for a real lift, but the wood was painted black and trimmed neatly .
'64 J200 thriftside
'67 J2000 townside custom cab
'68 Jeepster Commando
'69 Super Wagoneer
'75 J10
'79 Cherokee S WT
'75 Cherokee
'61 Aristocrat Lil Loafer
Old 12-20-2010, 01:44 PM
Dr. Marneaus's Avatar
Lets see....
1. Wired tons of crap in all with the same color blue wire (must have been on sale)
2. Painted the motor chevy orange.
3. Removed the main fuel tank and left only the aux tank from a Previous previous owner, and made it so i wont be able to put the main one back without major work.
4. Wired everything under the hood while blindfolded apparently.
5. installed an Edelbrock...grrr...
6. Installed a cat to get it to smog, then had a pipe welded in to make the cat non functional.
7. Repaired the AC lines with hose clamps.
8. Repaied everything else possible (side view mirror included) with hose clamps.
9. This....think it smelled good inside my truck for the first month?
Originally Posted by FSJunkie
The Mag - The Wag
Old 12-20-2010, 02:01 PM
Lets see....
OMG, is that a galvanized plumbing fitting on the filler neck?
'64 J200 thriftside
'69 Super Wagoneer
'75 J10
'79 Cherokee S WT
'75 Cherokee
Old 01-03-2011, 06:35 PM
Rudys78J10 Rudys78J10 is offline
Just started to pull back the house carpet in the J and found 4 layers of tar paper. All glued of course.
2007 Silverado - My DD
2008 XK - GF's DD
2000 TJ - GF's toy (soon to have 4" susp lift, 2" bl, 33's)
1978 J10 - My new toy
Old 01-03-2011, 06:45 PM
suzq044's Avatar
suzq044 suzq044 is offline
Levi:
De-smogged a california truck
got rid of the front driveshaft, and entire rear window assembly; i most of the in-cab wiring is suspect as well.
Max: None yet! Most of his problems are age-related.
Chuck (XJ):
left a crack pipe in one of the many open hoses under the dash.
Welded the tow-hitch to the body instead of attaching it appropriately to the frame.
Bondo'd the a-pillar to make it "look normal", while it is structurally unsafe, most likely.
It likely has a bent front subframe due to at least one head-on collision (we assume drugs were involved) We carfax'd the car, but nothing showed
under-hood wiring is now in question, as it seems to show the battery idiot-light fairly often in the rain, and we confirmed the alternator wiring may be to blame.
Regardless, it still runs (and off-roads) like a champ, and is only a 2.5L rwd .. lol
Max²: 1964 Jeep Panel Wagoneer
Planning Stages
2018 Wagoneer Rendering if you're interested.
Old 01-03-2011, 06:46 PM
palexand palexand is offline
...had the incorrect firing order, bastardized carb, no distributor rotor, so he off'd the thing to me for $250.
Old 01-03-2011, 07:02 PM
1983 j10's Avatar
1983 j10 1983 j10 is offline
found two bolts holding the trans to the engine on mine,
also they were to lazy to replace the reverse switch so they ran new wires from a toggle switch to the harness and hacked the main harness for power and ran a wire from that all the way back to the tail lights.
also wire nutted a trailer harness in on one tail light hacking up the harness there,
im sure there is more but i cant remember it right now.
1983 j10 lwb soon to be a 4.5l stroker AMC 20 rear 44 front 4spd manual in the process of restoring
01 xj 3" and 31's
Old 01-03-2011, 10:15 PM
Monkeyfrog's Avatar
Monkeyfrog Monkeyfrog is offline
When they installed the block lift (now gone) they left the u-bolts so long that they dented the bed of my Cherokee when the rig hit a big bump.
1982 Cherokee Chief: 258- T5 Transmission- Weber 38/38 Carb- Ford TFI Ignition- 4in lift w/31in MTR’s
Old 01-03-2011, 10:39 PM
ChiefIronLungs's Avatar
ChiefIronLungs ChiefIronLungs is offline
my PO was kind enough to LOSE THE LOCK KEYS so i gotta get a locksmith before i can raise or lower my back hatch *%^&$*%^
<<---<<< 1983 Jeep Cherokee Chief 87k original miles >>>--->>
Old 01-03-2011, 11:56 PM
dirtman's Avatar
dirtman dirtman is offline
I also have hose awesome galvanized plumbing fittings for my filler tube, not just one fitting though they extend all the way to where it 90's out the bed where the joint is made of electrical tape.
Told me there were carb issues and it would top out at 40mph on the freeway. Got it home and all the plug wires but one went to the wrong cylinders.
Old 01-04-2011, 12:19 AM
mic63's Avatar
mic63 mic63 is offline
90% rewired. Followed the old wire with the new. Did not remove the old. Some lines had wire several feet longer than need and were bunched up and tucked wherever they would stay. Lucky for me, it's a '63. Not a whole lot of wire to begin with, but it was a knarly mess to remove the old stuff and trim the new wires to the correct length.
1963 Wagoneer. 230 OHC Tornado. Three on the tree.
http://s146.photobucket.com/albums/r...63%20Wagoneer/
Old 01-04-2011, 12:20 AM
HerrKooled's Avatar
HerrKooled HerrKooled is offline
Cut notches into the bed so his truck box could sit in there.
Old 01-04-2011, 01:16 PM
JavaJeep JavaJeep is offline
House Glass
House glass in the door and rear windows on the J20 . I also had this on 2 Willys Jeeps , L E T H A L
Happiness is 40 something with a Jeep 20 yrs older and a woman 20yrs younger ... and a J20 in the driveway
Jeeps
1944 Willys FrankenJeep 134 cuin
1962 MitsuWillys Jeep 350 V8 5 speed project
J20 258/T18a/NP208/D44/D60
3 is enough for the moment
Old 01-04-2011, 09:24 PM
79 wagoneer's Avatar
79 wagoneer 79 wagoneer is offline
carb was horribly out of tune and needed to be rebuil, i had to drive it home with the (automatic trans) gear selector on the 2/second gear because it wouldn't stay running in drive. he also rebuilt the engine wrong, rod bearings were several thousandths to big (among other things) which resulted in them burning up, all 8 of them were worn down to the brass.
1979 Wagoneer : Rustys Offroad 6" lift, 35" BFG AT's
1995 XJ Cherokee: sold
2002 TJ Wrangler: Rough Country 2.5" lift, 32" BFG AT's, Daily Driver
Old 01-04-2011, 09:28 PM
acofficer's Avatar
acofficer acofficer is offline
carb
PO put a square bore Carter AFB on the spread bore intake, and couldn't figure out why there was a rough idle and possible vaccuum leak.
Old 01-05-2011, 07:40 AM
CutterN55's Avatar
PO told me the drivers side rear window "didn't work".
My guess is the motor went bad. I opened up the door panel to find a 5/8x 5 1/2" fence picket holding the glass up. All window parts removed except the switch. No motor, no motor mounting plate nothing. Just the switch, window track , and glass.
Hood ornament broken off and replaced by a gold Jaguar hood ornament and attached with a generous application of WOOD GLUE.
And it looks like they tried to sand the "wood" on the tail-gate.
ROMANS 12:1-2
'89 GW deceased
Ford 4spd swap Np435/205
Old 01-05-2011, 08:03 AM
drlocke's Avatar
drlocke drlocke is offline
Roadside Mechanic
I'm not sure which one gets the prize--the lawnmower carb rig-up or the beer case patch on the ceiling and no attempt to fix the leaky windshield....
Not an FSJ, but I saw a Willys truck with about 15' of 3/4 inch iron pipe and about 30 elbows all festooned about the motor for hydraulics purposes. Just changing the plugs--a simple job on the little flathead 4-banger normally--is a nightmare working through the monkey cage of pipe.
Old 01-05-2011, 08:51 AM
smogdredd's Avatar
smogdredd smogdredd is offline
Really
The PO unable to find the coolant leak cut a hole in the firewall to acess the back of the head, gave up and filled the radiator with ATF and kept thashing it around the desert. That was before it's second career as a doghouse.
'63 wagoneer '87 360 running gear except T case (207), warn hubs, 3.56 diffs and EFI Holley pro-jection using ford cfi throttle body Stock dist. with four wire HEI module.
'67 Scout 152cid w/EFI and turbo also My own a little help from Chrysler. I am a fabricator, I make stuff up!
facebookGGAutoCare
Old 01-05-2011, 12:54 PM
Left it basically stock, so I'm gonna be that dumb po that gets talked about, that is if I ever sell the thing or it gets sold off when I die.
George
'74 Cherokee, 401
'76 J-20, 401
M725, future project
Old 01-05-2011, 04:14 PM
NickyS.Peters's Avatar
NickyS.Peters NickyS.Peters is offline
You know the control arm that moves the window up and down? Well, the PO kept this from sliding out with a vice-grips...that explained why once I rolled down the window 1/2 way, it fell down b/c it apparently wasn't tight enough. Luckily the locking washer that was supposed to be there, was in the bag of spare parts that came with it...
4-High (and other things) Elwoody General FSJ Tech 6 02-03-2010 02:11 PM
why do simple things wreak such havoc??!! shaolinsifu General FSJ Tech 0 01-01-2010 08:24 PM
Stupid question johnwaynejeep2 General FSJ Tech 2 08-16-2006 01:17 PM
Things to do for Ouray.... BRUTUS Ouray FSJ Invasion 36 07-10-2006 08:23 PM
D44 question..found odd things in it Gambler68 General FSJ Tech 5 06-01-2006 09:12 AM
