The squirrels trashed my wiring under the bed, so I decided to take Terra down to replace the wiring (nose to tail) and since I have the summer and no projects, I figured I would do more.
To date: The bed is removed and new fuel lines, brake lines and ran the wire down the frame rail inside some black pvc. I also replaced the fuel sender and electric fuel pump.
I stripped the cab down to the floor and did some repair work to the area under the gas pedal...just a patch panel under there and the same for the passenger side.
Pulled the front clip to check for any more rusty spots and was happy to find none.
Pictures will come later as I try to figure out how to resize them.
Wayne S
Wayne S
