Well I've done a lot of searching this morning, (I have way too much free time at work some days ) but I still have some questions about break-in procedures and want to draw on the experience of some the good folks here.
First, the engine:
360 AMC, performer intake/carb, straight cylinders, (Less than 0.001" taper.) so just had them professionally honed. Block was already +.030". Re-ringed pistons with sealed power rings, chro-moly. New crank/rod/cam bearings. Polished crank. New ARP head bolts.
Stock exhaust mani's w/ 2.5" duals, X-flo dynomax muffler.
Howards Cams # 312481-11 w/ Rhoads superlube lifters. Howards Springs/retainers/locks. Re-used stock pushrods/rockers.
Valve job and check plane on heads and deck.
Summit HEI distributor and MSD wires. Bosch iridium fusion plugs.
Cleaned out stock radiator, flows good, no leaks. Flowkooler H2O pump and thermostat. Mechanical temp guage.
Oil pump rebuild kit from BJ's. Mechanical pressure guage. AMSOIL Ae filter and AMSOIL SAE30 break-in oil. Also installed a filter bypass to an oil cooler. Primed Oil pump, very good flow.
So now that that's all out there...
Howards Cams recommends the following break-in for the camshaft: Start engine, bring rpms immediately to 2000-2500, run for 20 minutes, drop to idle and run for 20 minutes, shut off engine, allow to cool, drain and change oil.
This differs from most of the engine break-in how-to's that I've read. I haven't seen a single one that recommends letting the engine idle for any period of time. Most say to start at 1500-2000 rpm and run it like that for at least 30 minutes.
Also, many of them say to retorque the head bolts after the initial run. How many of you have done this step? Is it really necessary with cast iron heads/block?
I'd like a run-down of what you all did to break in your rebuild, whether or not you had moly rings, and how long you have been running your engine without trouble since then.
Please throw in your $0.02.
First, the engine:
