Brake hardlines
  • 68_Gladiator
    • Oct 01, 2007
    • 1165
    Brake hardlines
    Anyone know if the 74-88 hardline kit from bj's could be adapted to a 73? Or am I better off buying tube and fabbing my own lines.
    "Go Brow or go home"
    1973 J2000
  • tgreese
    • May 29, 2003
    • 11682
    http://www.bjsoffroad.com/Brake-Line...el_p_1795.html
    '74 was the first year for open knuckle front axe, and had optional disk brakes. So it's not going to be the same. JMO - buy the Mastercool flaring tool, a roll of Nicopp line, rock guard and make your own. The Mastercool tool makes flares almost effortlessly, and you'll have the tool after you are finished.
    • 68_Gladiator
      • Oct 01, 2007
      • 1165
      I was looking at the Westwood tool. Watched some YouTube videos of it and it seems pretty solid.
      1973 J2000
      • joe
        • Apr 28, 2000
        • 22392
        As tim mentioned. Unlikely to be a bolt-in for a 73.
        As BJ's description mentions:
        "Note:1978 and Later are Direct Fit (1974-1977 May Require Minor Modifications)" For a 73 that tells me it "will" need to be modified. If ya gotta modify it, why spend $195 up front? Much cheaper to buy the tools/tubing and roll your own.
        • 68_Gladiator
          • Oct 01, 2007
          • 1165
          Is it all 3/16 line?
          1973 J2000
          • tgreese
            • May 29, 2003
            • 11682
            https://www.eastwood.com/professiona...BoCkJUQAvD_BwE
            What I've read, those that have that tool like it. I believe it has to be in a vise to be used - it has a long handle and uses muscle power to form the flare. The Mastercool can be used on the car, with the tubing end hanging in mid-air, and is hydraulic. More expensive.
            You might look here for some owner's reviews - https://www.google.com/search?source...d+flaring+tool
            If it's like my J-10, everything is 3/16" except the lines from the master cylinder to the combination valve, which are 1/4" (?) IIRC. Your '73 may not have a combination valve - should be shown in the TSM. Possible you have a distribution block with a brake failure sensor. The first lines from the MC would go there.
            • 68_Gladiator
              • Oct 01, 2007
              • 1165
              I think I'll give the Eastwood a go. I don't mind removing the line to flare it. I have a portable work table with a vise on it so I can do it right next to the truck. With the price difference between the tools I can use that towards the other 1000 things the truck needs. Looks fairly straightforward, I'll buy a bit of extra line and practice first.
              1973 J2000
              • Kaiserjeeps
                360 AMC
                • Oct 02, 2002
                • 2811
                I have that flaring tool and it makes flawless flares first time and fast. Deburr the line first and you will not be able to tell the difference from a factory flare. It was worth every penny. It will also do bubble flares for putting a clamped rubber hose on metal tubing. Comes with several sizes too,
                I also bought the on car 3/16 double flare tool eastwood has. It also makes fantastic flares. But they take way longer. The turrent tool above is the last flaring tool you will ever buy.
                Melford1972 says...
                I make wag parts
                1969 CJ-5 41 years owned
                1968 M715 restomod
                2001 Dodge 3500
                2002 Toyota Tundra
                Small violin, large amp
                • 68_Gladiator
                  • Oct 01, 2007
                  • 1165
                  You've sold me. Ordering one and their deburring tool. May as well make new fuel lines while I'm in there, get some more use out of it.
                  1973 J2000
                  • 68_Gladiator
                    • Oct 01, 2007
                    • 1165
                    Got the tools, waiting on the line to come in and this snow to melt to I can drag the truck back to the house
                    1973 J2000
                    • Mars
                      • Apr 24, 2010
                      • 1195
                      cool
                      Wannabe Fabricator
                      Grumpy on a good day.
                      • Rusty76
                        • Jul 15, 2018
                        • 331
                        Nice! Keep us updated.
                        1976 Jeep Wagoneer
                        Rebuilt, 360, TH400, QT.
                        Still not running. Soon!
                        • KaiserMan
                          I got the Willys....
                          • Jun 21, 2005
                          • 8704
                          Be interested to see how you like that. I was looking at one a while back but went with the Mastercool hydraulic kit instead.
                          1971 Gladiator
                          • 68_Gladiator
                            • Oct 01, 2007
                            • 1165
                            I will let you know. As soon as I get some line in I plan to practice a bit.
                            1973 J2000
                            • rang-a-stang
                              • Oct 31, 2016
                              • 5512
                              Frieburger JUST did a Roadkill Extra on that tool. Like last week. He said it was one of his favorite tools and every garage needs one.
                              Chuck McTruck 71 J4000
                              (Chuck McTruck Build Thread)
                              00 Baby Cherokee
