So last Saturday after a bit of driving the '91GW wouldn't start after sitting for about 20-30 minutes. It was pretty warm and we had been running the A/C. I fiddled with it for about 1/2 hour and it fired up and we took off for home. Made it to about 1/2 mile from the house and it died just like the key had been turned off.
Suspecting the module I replaced it with a Standard piece from O'reilly' the next morning
. Engine was fully cooled off and it fired right up. I let it run until it got to operating temp then shut it off for about 20 minutes and it would not start, sounded like it wanted to but no go. Took the module back to O'reilly's and it tested as bad, as did the original one I removed. Ordered a 2nd module and got the exact same results, cold start fine, but no hot start and that module also tested bad.
Ordered third module, but this time when I tried the hot start test I shot a bit of starter fluid in to make sure it wasn't a vapor lock issue. No hot start!
I ordered a 4th module from NAPA and in the mean time I changed out the pickup coil in the distributor. It started cold but was running horribly like it was far out of time, backfire, fart, belch, stumbled and died on acceleration, just ran like crap. I removed and reinstalled the new pickup to make sure I hadn't missed something but no good. I removed the new pickup and reinstalled the old one, started right up and ran like it's supposed to.
I'm now waiting for a module I ordered from BJ's to arrive tomorrow, according to them it's a Crown unit not a Standard. Fingers crossed for hot start fix.
Anyone have any advice on my procedure so far or what other component might be causing the problem. It gets pretty damn old replacing parts with "new" junk parts, thank God I'm not trying to make a living at this
