PS Exhaust Working...
__Of everything I have done I am most concerned w/ this area. Where the exhaust passes by the front double cardan and TC. It's really tight so I have to strap things so as not to move, thus why the flex joints in the exhaust. Here is what I have so far. The paint is drying on the x member then it will go up and I can move on to wrapping the exhaust section aft of where I have already done it. There is a clamp there so it will be a real chore to wrap it and make it look presentable as well.
__The wrap is rated at 2000* and you put the shiny side Out. Adding to it I wrapped that w/ a 325* rated foil tape in an attempt at making the wrap last longer and survive water / pressure washing easier.
__The access to the custom ubolts to install and remove is via dropping the X-Member.
__Who says this will not work. I want to here opinions... Am I going to cook my TC? Have you seen pipes closer and perhaps a worse job and it all worked fine? I would love to get some comments. Were navigating thru uncharted waters here, dam the torpedos, full speed ahead.
Here is the heat wrap material I chose. It comes in 36 x 60 and there is the foil tape as well. One side of the wrap is white. It appears to be some
substancial material...we shall hope.
