Old 06-22-2002, 10:04 AM
johnypreflt johnypreflt is offline
Question
Ok heres what I have. a stock am/fm/cassette from an 81 Waggy. my question is does anyone know what color wire goes where or have a wiring diagram for the radio? the following wire combinations come out of th radio: 1)red wire & blue wire that share a connector. 2)orange wire, black wire, brown wire with 5amp inline fuse that share a connector. 3)white wire by itself.(power antenna maybe?). 4) green wire with white stripe, white wire with black stripe, solid black wire that share a connector. 5) solid green wire, solid white wire, black wire with white stripe that share a connector.
Any and all help appreciated. Just dont want to fry the unit by putting power to wrong wire!!
BLUE BEAST,1980 J-10 (FOR SALE)
CHEVY 350,th350,33" SIDEWINDERS
PICS http://www.fsjworld.com/prefltspage/
prefltjohny@comcast.net
Old 06-23-2002, 02:50 AM
graham's Avatar
graham graham is offline
johnypreflt
The following is from the Haynes manual wiring diagram, '72 thru '91 Wags and Pick ups. It's titled "Typical Audio System"
VIO/WHT connects to VIO/ORG from the Radio fuse, 15A in the fuse block.
Next two are for Electronic Tuning Only;
BLU connects to DK BLU from light switch.
PNK connects to RED/TAN from ETR Fuse, 10A in Fuse Block.
GRY to GRY for Power Antenna.
ORG/WHT connects to ORG/WHT from instrument panel Intensity.
WHT connects to WHt for RF Speaker.
BLK connects to BLK and connect to both right side speakers.
WHT/BLK connects to WHT/BLK for RR speaker.
GRN/WHT connects to GRN/WHT for LR speaker.
BLK/WHT connects to both left side speakers.
GRN connects to GRN for LF speaker.
BLK connects to BLK which is Earthed.
Hope this helps [img]smile.gif[/img]
Graham
Lifes to short ..... eat dessert first.
'82 Cherokee Sportsman II,360, auto. As it rolled of the Show Room floor. Except for; LPG conversion, On board air, O2 sensor, rear shackle flip and extended front shackles....Dual batteries on the way Model T timing.
Bearhunters Home Page
Old 06-23-2002, 06:36 AM
andy d andy d is offline
Shade Tree Shaman
Cool
this would have been a big help coupla hrs ago. i'm on the install phase of putting a pioneer cassette deck harvested from a former jag. because the original is a POS. i peaked at the speakers as the pinout diagram on the radio is dyslexic. thanks Graham
\'88 gwag,pure stock
Am/Fm/CB radio wiring help Ghinmi General FSJ Tech 5 01-15-2006 06:45 AM
factory cb radio, any good? FSJsteveo General FSJ Tech 14 03-16-2005 12:57 PM
am/fm/cb radio wiring? miked General FSJ Tech 5 11-15-2003 03:45 PM
