Old 04-28-2016, 01:21 PM
Honchov8 Honchov8 is offline
Factory am/fm CB mic mounting question
I'm getting ready to do the install on my 76 J10 with a very nice used AMC AM/FM CB. I have everything for the install including the antenna splitter but I'm confused on how the factory held the female end of the microphone hook up in place once it came through the metal dash. Was there some type of "C" clamp that kept the connector from being pushed back through the dash? I've seen several photos of the connector sticking out of the dash without the microphone cord hooked to it. I'm just confused what would keep it from being pushed back behind the dash when you go to plug in the male microphone plug from inside the cab? Any help will be greatly appreciated.....
1976 J10 Honcho "Z" code
Old 04-28-2016, 05:25 PM
autogatto's Avatar
autogatto autogatto is offline
If I remember right there's a little ring that screws onto the connector so that stays in place
1977 CJ 5 401cid, 1979 CJ 5 343cid, 1979 cj 5 304cid, 1976 CJ 7 304cid, 1981 J 10 360cid
Convert my factory ball hitch to 2" receiver? HEJ General FSJ Tech 3 04-08-2014 08:32 PM
roof rack mounting hole question Damaged Goods General FSJ Tech 4 12-21-2007 06:35 AM
Body and frame mounting question ohioj20 General FSJ Discussion 3 08-08-2007 01:13 PM
factory foglamp question? DanH General FSJ Tech 16 02-20-2004 02:43 PM
Fan shroud mounting question Matthew W. Woodruff General FSJ Tech 4 06-10-2003 03:15 AM
