Old 04-23-2017, 11:13 AM
AMC 4 barrel to TBI plate?
I have a 401 that is going to get 454 TBI slapped on it. Right now I'm on a four barrel intake with a Holley spread bore TBI adapter. If you are up on carbs, you already see the problem: the 4350 spread bore that AMC used is *not* the same spread bore that the Holley adapter was made for.
So, what's the solution here?
It looks like a die grinder might fix my problem.
Would a 2-barrel AMC intake work?
Edelbrock Performer intake?
Some other adapter that is designed for the AMC intake?
I got the Holley adapter free (birthday present) not realizing that "spread bore" wasn't sufficiently detailed. I don't want to spend $300 making a $60 part work, though.
Old 04-23-2017, 11:41 AM
TexasJ10's Avatar
TexasJ10 TexasJ10 is offline
Hamilton has good options for tbi adapters
http://hamiltonfuelinjection.com/cat...-adapters.aspx
Old 04-23-2017, 12:07 PM
Get a hold of a square bore intake, I don't believe anyone makes an adapter for the amc motorcraft 4350 4bbl intake.
Plenty of used intakes out there if you don't want to pay for new.
Old 04-23-2017, 08:32 PM
Hah! It looked like there was no way it would fit, with 1/4" or so of intake manifold showing under the adapter plate.
The 454 TBI unit can open all the way with no interference, though, so it'll run.
I'm going to use a die grinder to smooth the transition from adapter to intake manifold to minimize the harm there and eventually I'm going to buy an aluminum intake manifold - but it'd work with *zero* mods.
Old 04-24-2017, 04:45 PM
Blinkinlights's Avatar
Blinkinlights Blinkinlights is offline
Transdapt 2199 will go from AMC/Ford spreadbore to Holley square bore.
87 Grand Wagoneer 360/727/NP208
BJ's Front and Rear Dozer Bumpers
35x14.5x15 Boggers on 15x10's
Mile Marker H10500 Hydraulic Winch
http://photobucket.com/albums/y174/bANGr/
It's all fun and games until someone breaks a woodie.
Old 04-26-2017, 07:29 AM
Woodchomper's Avatar
Woodchomper Woodchomper is offline
Whatever adapter you end up using make sure the TBI unit fits properly. The newer 454 TBI have a larger base. Check out the pictures in the link below:
https://www.thirdgen.org/forums/tbi/...-using-gm.html
1991 GW 401 /727TF/NP229 /4" Skyjacker /EBL TBI /CS-144
1981 J10 401 /727TF/NP208 /6" Superlift /CS-144
Old 05-07-2017, 11:16 AM
Bill USN-1 Bill USN-1 is offline
http://www.binderplanet.com/forums/i...utions.105992/
Bill USN-1
Fuel Injection Moderator at BinderPlanet
Hamilton Fuel Injection
75 scout XLC 345/727/JPD300/3.73's/33's/4wdisc/hydroboost/EFI/OBA/OBW
1977 Innocenti 1001 (Italian Mini)EFI 1275/DIS
Old 05-07-2017, 07:31 PM
Mr. Wilson's Avatar
Mr. Wilson Mr. Wilson is offline
I got mine from Bill at binder planet. I put it directly onto the spread bore intake in the 76 and put the TBI straight onto the adapter. I drove it to and from work today, about 75 miles. It works great and if you tell him spread bore he'll send the correct gasket. I would call Bill at binder planet, his adapter is top notch. Heck it looks like it's aircraft grade.
76 Wagoneer 360/T400/QT
69 F100 SWB 390/5 speed
TBI Fuel pump choices srobertsfsj Fuel Injection 5 08-16-2011 05:44 PM
TBI injector size Hutti Fuel Injection 2 10-19-2008 09:24 AM
Strange thing with my Howell TBI (kinda long) ne715 Fuel Injection 0 04-13-2008 04:48 PM
401 intake and carb ?'s 2 or 4 barrel scottsaint401 General FSJ Tech 8 04-09-2008 06:55 AM
D.I.Y Throttle body injection write up (With pics!!!!) and this is no haox Wagoneerlover Fuel Injection 28 06-25-2007 12:43 PM
