Old 09-21-2018, 06:38 PM
cjarcher's Avatar
cjarcher cjarcher is offline
Burst radiator
Hi all, I just bought a very nice '85 Wagoneer. Drove it home about 150 miles, all was good. Stopped and as soon as I turned it off the radiator burst. Toward the top of the radiator, the part that holds the cap separated from the finned part. It burst pretty violently and spewed a lot of coolant. Any idea what caused this? Coolant temp was low until about 5 minutes before I shut it down, the temp started to creep up. I am thinking when I shut it down, the fan stopped cooling and this is what pushed it over the edge. Any ideas as to why radiator would burst without he cap bursting first?
'85 Grand Wagoneer
'16 JK 2 Door, 6 speed (sold)
'82 J10, 258, tf904, np208, 2.73 (sold)
'96 ZJ 5.2 (sold)
'98 ZJ 4.0 (sold)
'76 CJ5 232 (sold)
Old 09-21-2018, 08:50 PM
crappy old radiator, poorly soldered seems, radiator cap not working, a lot of things could cause this, just replace the radiator and hose and water pump, thermostat while your in there, save you from doing it all later.
Old 09-21-2018, 08:58 PM
cjarcher's Avatar
Thanks for your advice Wiley. I will replace the radiator. The previous owner had re-cored the radiator and replaced the water pump, although this was 14 years ago. The coolant looked very fresh. I suppose now that the radiator has exploded, it will have to be replaced.
'85 Grand Wagoneer
'96 ZJ 5.2 (sold)
'98 ZJ 4.0 (sold)
'76 CJ5 232 (sold)
Old 09-22-2018, 08:08 AM
make sure to do the other stuff while in there, piece of mind more than anything, no one likes being broke down.
Old 09-27-2018, 11:07 AM
Although I havn't seen one, I would also check for a defective cap. If something is preventing the release of pressure in the cap the pressure will go out somewhere else.
Resistance is not futile yet.
Old 09-29-2018, 02:28 PM
Mr Carts Mr Carts is offline
This is exactly why I run a zero pressure radiator cap on my Cherokee.
1980 Cherokee WT 360 TFI Contour Fan 727 208
3.31 285/75X16 Duratrac's E rated
Cummins Radiator and Cooling Help Iceman0502 Diesel Swaps 17 02-24-2013 10:15 AM
Second radiator and dual batteries budojeepr General FSJ Tech 24 07-20-2010 11:36 PM
Coolant flows too fast - myth or truth? shimniok General FSJ Tech 107 02-10-2009 08:02 AM
Need Radiator Cap or maybe a new Radiator, (PLEASE HELP) Jeepeta General FSJ Tech 3 12-18-2006 08:52 PM
probably not the last word on cooling.... brent General FSJ Tech 38 07-18-2003 08:29 AM
